Tires Camber Issues With Kubota RTV 1100
   / Camber Issues With Kubota RTV 1100 #1
jpinkston70
Glendive, MT
Kubota RTV 1100
I have a Kubota RTV 1100 bought it used in Missouri and had it brought to me here in Montana. When it got here i noticed it had a really bad camber issue on the front caused by the 2 inch lift kit that was already on it. I didn't pay much attention to it at first till about a month or so later when I noticed my tires were wearing really badly on the outside. I took off the lift kit on the front hoping it would help. It slowed down the wearing but it is still pretty bad. Is there any way to correct this problem?
   / Camber Issues With Kubota RTV 1100 #3
Does it have the heavy duty struts that are needed for a snow plow? That causes a slight camber issue without the weight of the blade. I don't think it would tear the tires up unless you drive it a lot on solid sufaces.
If you look at the lower part of the push bar, you might be able to tell if there was a subframe bolted there, also there may by hydro lines in the front.
Just a thought.
No It doesn't have the hook ups for a plow. As for the tire wear I drive it on the streets here in town since Montana allows ATV's and UTV's on the streets. I'll get outside and look though just to be sure.
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A52128)
Kuhns AE10 Small...
Wilrich Field Cultivator (A50515)
Wilrich Field...
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
2016 BMW X5 sDrive35i SUV (A50324)
2016 BMW X5...
2013 Nissan Sentra (A50324)
2013 Nissan Sentra...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A51573)
IMPORTANT PLEASE...
