Tiller calling all king kutter tiller owners
   / calling all king kutter tiller owners #11
I have a Kioti ck35 with industrial tires. I have been using a King Kutter 60inch tiller for two years and the width is perfect. My tires are not off-set (wider than standard with a spacer kit) and the tiller just covers the tracts fine. There is plenty of hp to spin the 60inch tiller and I can run it in second gear in ground that has been previously worked before. However I stick to first gear on virgin ground. I have found that the tiller does not need to be run at 540rpm, and can work just fire at a lower rpm. This tiller has been, for lack of a better word, GREAT. I now have met all my neighbors (tilling their gardens for free), and a little help with a neighbor in the country goes a long way. Good luck with your decision!
   / calling all king kutter tiller owners #12
I have 25 pto hp and I do fine.
The only time I ever notice the tiller is when I am tilling DEEP in previously tilled ground. Then I just slow down a bit. It's easy with a hydro tranny is you have one.
To answer one of your original questions, yes a 5 ft KK cuts a full 5 feet.
   / calling all king kutter tiller owners #13
I apologize. I fully meant to say what tractor outside dimensions were, it's 60". It's a JM354 Jinma with R-1's. I just kinda get wound out using a utility size tractor to help out people with the small garden plots that actually needs to have the small self propelled tiller doin' the work. I need to start saying "No" more often and then being honest and saying why I can't do the work. bjr
rick whats the width of you're tractor outside of tire to outside of tire mines 66".
   / calling all king kutter tiller owners #15
i am about to purchase a tiller i'm looking at king kutter @ tsc. i can't use a 4' because even with the offset it still dosent cover the wheel tracks. i'am at 5' wide because of r4's i measered one at tsc yesterday, they did not have a 5' to measure. my question is the 5' really 5'. will the 5' tiller actually cover my tracks. could someone please help with this before i make a mistake.
My neighbor has the same frame tractor as yours but it is a farmtrac and he has the 5' KKII tiller. It clears the tires but barely. It is a good match though. He put my 6' KKII tiller on and it worked good but it made his tractor work.:D
I say you will have no problem with the 5' tiller.
   / calling all king kutter tiller owners #16
Not an answer to your question, but have about a 4ft length of 2 by 4 handy at all times when using this tiller.
Mine will jam on rocks and segments of roots, once it has torn through them and pulled them up.
Use the 2 by 4 as a lever to turn the tiller backwards {Engine off, PTO disengaged, tractor brakes set, etc}
I have never had to use anything to pry rocks out with. I have had quite a few make the slip clutch slip. I just shut the PTO off and drive backwards a couple feet with the tiller on the ground. It has always made the rock dislodge without ever getting off the tractor.
jd is it possible to get a measurement on the tire width. i know this is a pain and they should be the same tractor but mine is an ls and his might be a lg which could make some difference.
   / calling all king kutter tiller owners #18
I will work on getting a measurement. For now here are a couple pictures of his tractor with the tiller on it.
i see adjustable rims mine are not they are as narrow as they get.
   / calling all king kutter tiller owners #20
My neighbors tractor width is 61" to the outside of the tires.
That kind of sucks that your tires are not adjustable.
2005 FORD F-450XL SUPER DUTY DUMP TRUCK (A57192)
2005 FORD F-450XL...
2018 RAM 2500 SERVICE TRUCK (INOPERABLE) (A53843)
2018 RAM 2500...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52707)
KNOW BEFORE YOU...
Honda Pioneer SXS700 4X4 Utility Cart (A55787)
Honda Pioneer...
2018 RoGator 1100C (A55315)
2018 RoGator 1100C...
2006 Mercedes-Benz (A55758)
2006 Mercedes-Benz...
