Calling All Gear Heads -Need Brake Drum Help
   / Calling All Gear Heads -Need Brake Drum Help #1
Travelover
Elite Member
Washington
B7100
I'm adding brakes to a trailer made by UHaul, so it is a little of an odd duck. They used 93 Camaro sealed front hubs for wheel bearings on a 4.75" bolt circle.
My problem is that I need to find some brake drums that will slide over the hubs (like the rear drums on a RWD truck) that are 10" diameter and fit the 4.75" bolt circle. UHaul made another trailer with these hubs and brakes, so I know they exist, but are now obsolete from UHaul. I'm sure they just adapted some drums from another application, but I need help figuring out what that might be.
Why not just use Camaro drums? Camaro drums are 9.5" and electric brakes only come in 10" and 12" sizes.
Any suggestions?
   / Calling All Gear Heads -Need Brake Drum Help #2
Any suggestions?
Try rear drums from same model year S-10. I believe they will work.
   / Calling All Gear Heads -Need Brake Drum Help #3
My brake spec book says S-10 drums are 9.5 but some C-10's from 88-91 had 10" rear drums. Don't know if they are 4 3/4 BC though but a machinist could redrill whatever bolt circle you need easy. hth
   / Calling All Gear Heads -Need Brake Drum Help #4
there are add on disk and maybe even drum brakes for boat trailers.. Check somewhere like west marine
Does this jog any memories?
Here are all the vehicles that use a 4.75" bolt circle:
1987-82 BUICK - Regal
1985-79 Riviera
1985-77 LeSabre (Ex H.D. Pkg.)
1983-61 Century, Gran Sport, Regal, Special, Sportwagon
1979-73 Apollo, Skylark
1985-79 CADILLAC - Eldorado
1985-80 & 76-75 Seville
1996-87 POST OFFICE VEHICLE - GM
1999-83 CHEVROLET - "T" Series (4WD), Blazer, Pick Up
1998-82 "S" Series, Durango, Sport, Tahoe, Pick Up (2WD)
1995-66 Camaro, Berlinetta,
1990-77 Caprice, Impala, Belair, Biscayne, Kingswood (WO/H.D. Pkg.)
1989-70 Monte Carlo
1987-69 El Camino
1985-65 Malibu, Chevelle, Laguna
1982-68 Corvette
1981-67 Camaro Z-28
1981-66 Chevy II, Nova
1999-83 GMC TRUCK - "T" Series (4WD)
1998-82 "S" Series, S - 15, Seierra Classic, High Sierra, Gypsy, Jimmy, Pick Up (2WD)
1979-71 Sprint
1998-96 ISUZU TRUCK - Hombre
1994-91 OLDSMOBILE - Bravada
1987-69 Cutlass, F85, 442
1985-79 Toronado, Toronado Trofeo (FWD)
1985-77 Delta 88, 98 Regency
1994-71 PONTIAC - Firebird
1986-77 Catalina, Executive, Safari Wagon (WO/H.D. Pkg.)
1986-71 Bonneville, Grand Prix, GTO, Lemans, Tempest
1980-69 Trans - Am
1979-71 Ventura, Phoenix (RWD)
Thanks, I've looked there. I'm adding electric brakes, so discs won't work.
   / Calling All Gear Heads -Need Brake Drum Help #7
How many have the 10" drum or am I missing what you are looking for?
I didn't see any cars listed as having 10" I looked thru all of GM from 1970-2000 but you might check Raybestos or one of those sites for more specs but like I said I couldn't help ya.
Car Doc, thanks for looking. As far as I can tell, none of these listed have a 10" drum - lots of 9.5" and 11" (I'm looking at the Rock Auto site).
I'm sure UHaul didn't make up their own part, though, so there has to be an off the shelf part, if I can find it.
   / Calling All Gear Heads -Need Brake Drum Help #9
Welcome, you would be surprised how many short runs of special order parts these big company's can get done at a big parts supplier it could well be any 10" drum and 4 3/4 BC with the proper hub center cut in.
I could easily do a couple drums on my brake lathe and draw a new CL around the face of the drum and simply correctly locate and drill the new spacing on a Chevy PU drum if I needed too so anyone can do it if none can be found its not a huge deal really :thumbsup::thumbsup:
(I wouldnt want to go into production but a one of two of would be no biggy)
2013 CATERPILLAR D5K2 LGP CRAWLER DOZER (A52709)
2013 CATERPILLAR...
1998 Caterpillar 12H Articulated Motor Grader (A55973)
1998 Caterpillar...
Freightliner Tender Truck - Adams Tender (A56435)
Freightliner...
2007 Ford F-750 2,000 Gallon Water Truck (A55973)
2007 Ford F-750...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
