Calling All Ford Techs/Code P1450
/ Calling All Ford Techs/Code P1450 #1
OKnewguy
Platinum Member
Edmond, Oklahoma (OKC)
Jinma 224
Hi gang, I have a 04 E150 work van that is throwing up a P1450, which I understand to be "Unable to bleed up fuel tank vacuum". Here are the symptoms:
1 Just recently the P1450
2 I have to barely trickle the gas in at the pump, I mean SLOW, or it will shut the pump off.
It seems to run fine, I have found that this could be caused by:
-- EVAP canister purge outlet tube (EVAP canister purge valve to EVAP canister) blockages or kinks.
-- EVAP canister tube (fuel tank to EVAP canister) blockages or kinks.
-- Fuel vapor elbow on EVAP canister contaminated.
-- Restricted EVAP canister.
-- Canister vent (CV) solenoid stuck closed (partially or fully).
-- Plugged or contaminated CV solenoid filter.
-- EVAP canister purge valve stuck open.
-- Fuel filler cap stuck closed (no vacuum relief).
-- VREF circuit open in fuel tank pressure (FTP) sensor.
-- Damaged FTP sensor.
What should I work on first? And how to diagnose.
Any help would be greatly appreciated.
Dave
Btw, I have pulled the tank and checked the filler tube and over flow/cut off tube.
/ Calling All Ford Techs/Code P1450 #2
When you say you check the tubes when you pulled the tank what do you mean? Seems like you have a restriction somewhere.
Chris
/ Calling All Ford Techs/Code P1450 #3
All the newer vehicles have a small amount of vaccum on the fuel tank to keep the fumes in . The cheapest thing to try is the fuel cap . It may be hard to find the problem . I do know the dealer uses a smoke test to check for leaks . The light could even be set if you leave it running while fueling it . ( not common )
Sorry guys let me clarify a few things, I dropped the tank down on jack stands and undid the filler hose and the tube on top of the filler hose. This is the tube that goes back up to the fuel inlet and shuts off the fuel nozzle at the gas station. I also forgot to tell everyone that I did try a new cap.
Hope this helps.
Dave
/ Calling All Ford Techs/Code P1450 #5
Did you blow air through the vent line or better yet replace it? It seems like this has to be the problem or a restriction somewhere since it has problems filling up at the gas station.
Chris
I have not done anything yet to the vent line going to purge valve and then the canister (If if understand this part of this system). I have visually inspected it. It comes out of the tank and then heads to the very back of the van, there are a couple of sections with different sensors and valves it looks like. I was not sure how this system should act under "normal conditions", it sure seems extremely complicated for a gas tank vent. Should this be my next step?
Dave
Okay gang, I have off today and tomorrow. I dropped the tank out, and got to really inspect everything. I blew air from the tank all the way back to thru the rest of the emissions stuff vent line (long hose that goes to the back by the spare, thru the canister purge valve, etc) This all seemed fine. I did notice a bad connection after the cannister/black thing were I believe the purge valve connects up. It just pushes in. This might be the code tripper???? When I shot air from the back toward the tank, it would take air but then blow it back like it was pressurized. I then completley undid the vent line where it goes into the tank, and blew the line from front to back and it is good.
When I shot air into the vent nipple on top of the tank, it takes it but blows it back. NO AIR comes out the main filler hose. Now remember that I have to barely trickle gas in at the pump (painfully slow). I am not quite sure how this is supposed to work, BTW the overflow shut of hose that goes up to the filler nozzle comes off the vent hose, so gas is bypassing a lot of the tank and going right into the vent hose. I am going to get the fuel line disconnect tool now and pull the tank out from under the truck and have closer look.
Thanks, Dave
/ Calling All Ford Techs/Code P1450 #8
I think you are on to it. I believe its a venting problem. It could be something as simple as some mud dobbers building a nest.
Chris
Well I got everything taken apart, opened up the tank too. There is a plunger like thing that attaches to the vent. I took it apart and it seemed to move freely (I really do not know if I did anything with it). I put it all back together, and went and picked up my daughter from school, I swung by the gas station and put around 10 gallons in, it was the first time in ages that I could pump at full speed!!!! I really am not sure what changed but, it definitely works better. I reset the check in light with my scanner and will see if it trips. Hopefully this this code was set by that purge valve being loose.
BTW, I find it CRAZY all of these emission things on a vent line.
2 wired connectors inline with the hose
the huge cannister thing
the purge valve
and then a box with what looked like an air filter
Thanks everyone, Dave
/ Calling All Ford Techs/Code P1450 #10
Just think, your vehicle is somewhat old tech when it comes to emissions. The 08's and newer have tons more junk. Try working around newer vehicles emission crap. I pulled a elderly couple out of the ditch along I 70 a year ago in some big GM thing, not sure if it was a Buick or what. Anyway there were a few hoses hanging down near the gas tank from going in the ditch. They were worried about them but the car ran fine so I just tied them up and told them to take it to the dealer. Anyway it was full of canisters and hoses back around the gas tank.
Chris
I know that all that crap is for the environment, but I have to wonder; these kind of efforts are such a pita is it really worth it. It is kind of like the new gas cans, and in the summer they come on the news and say don't gas up during the day and don't run your lawn more during the day. And all the new emissions stuff on lawn mower and small engines. I know your into boats too; it is like the regulations/bans some lakes have on 2 strokes. The thing is the US and Canada can start all these regs. but the third world countries are the main polluters imho.
Dave
/ Calling All Ford Techs/Code P1450 #12
Boats are getting worse. If you or anyone is in the market for a boat get one now. The new outboards are going up in price every day and the inboards will be required to have Catalytic Converter systems adding nearly $3000 to each engine I have been told.
Chris
/ Calling All Ford Techs/Code P1450 #13
Just a sign of the time I think. When they want to outlaw the poppet QA because of the minute bit of oil they drop when connected or reconnected there something wrong.Glad you found the problem. Lots of labor and swearing im sure but doesnt sound like it was costly other than the labor.
Yep so far I only have time invested and the fuel line tool (which I already have somewhere but could not find). I hope I got it straightened out, I am keeping my fingers crossed. I have heard about the catalytic converters beeing required, that is going to add a whole new batch of issues to i/o's. I am willing to bet that the whole exhaust system from manifolds to the bellows and out board will need to be redesigned. I would think that the whole thing will now be running much hotter and then you can have all the issues with vaporlock etc.
My first boat had a 70 evinrude out board, ran like a champ. It only smoked the first start up of the year, it might have made some pollution, but it was a VERY efficient package with that little 16' boat, so how much was the pollution when looked at this way? BTW, I sold this boat to my little brother, and it has been so freakin reliable. Still has perfect compression.
Dave
Generac QT04854 Anax 48kW Generator (A61572)
Generac QT04854...
2023 Case TV380 (A62177)
2023 Case TV380...
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
1978 Fruehaue Chipper Trailer (A62613)
1978 Fruehaue...
10 ft bed. 14 ft trailer (A61567)
10 ft bed. 14 ft...
Safety Basket Forklift Attachment (A61572)
Safety Basket...
