Ballast Calcium in tires?
   / Calcium in tires? #1
bobhall
Oregon
I have a TC30 which I bought new in 2006, the dealer put calcium in the rear tires for ballast, when I tried to check the pressure the calcium started to leak out.
Unfortunately the dealer went out of business, so I can稚 can稚 contact him, my question is, does the calcium affect the valve stems?, corrosion, etc.?
If so, is there a special valve stem to use for replacement?, and do you have to jack the tire up, or just have the valve stem facing to it痴 highest point to change the stems?
Thanks for the help
   / Calcium in tires? #2
The stems will be fine.
Your gauge on the other hand....
   / Calcium in tires? #3
Actually, I believe you can get gauges for calc filled tires.
Then again, I've known standard ones that have lasted a long time. Just flush them clean afterwards.
   / Calcium in tires? #4
Just take your reading when the valve stem is posistioned at the top of the tire. The Tire is not fill all the way with the solution, you have to leave some air in it for give.
   / Calcium in tires? #5
I had a badly leaking tire that I took to a tire shop. They were able to replace a whole stem insert (not just the little thing in the end). If it is just the valve, they are cheap and easy to replace.
I recently aired up my tires, relying on the pressure gauge in the pump, which then stays clean as long as a little air is moving.
2021 Kubota RTV X900 4x4 Utility Cart (A55787)
2021 Kubota RTV...
2018 BOBCAT T740 SKID STEER (A52706)
2018 BOBCAT T740...
2015 Ford Escape SUV (A53424)
2015 Ford Escape...
JNC 1224 Jump Box with Charger (A54865)
JNC 1224 Jump Box...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A55315)
2003 International...
Kawasaki NR (A50324)
