Ballast Calcium in tires?
   / Calcium in tires? #1
bobhall
Oregon
I have a TC30 which I bought new in 2006, the dealer put calcium in the rear tires for ballast, when I tried to check the pressure the calcium started to leak out.
Unfortunately the dealer went out of business, so I can稚 can稚 contact him, my question is, does the calcium affect the valve stems?, corrosion, etc.?
If so, is there a special valve stem to use for replacement?, and do you have to jack the tire up, or just have the valve stem facing to it痴 highest point to change the stems?
Thanks for the help
   / Calcium in tires? #2
The stems will be fine.
Your gauge on the other hand....
   / Calcium in tires? #3
Actually, I believe you can get gauges for calc filled tires.
Then again, I've known standard ones that have lasted a long time. Just flush them clean afterwards.
   / Calcium in tires? #4
Just take your reading when the valve stem is posistioned at the top of the tire. The Tire is not fill all the way with the solution, you have to leave some air in it for give.
   / Calcium in tires? #5
I had a badly leaking tire that I took to a tire shop. They were able to replace a whole stem insert (not just the little thing in the end). If it is just the valve, they are cheap and easy to replace.
I recently aired up my tires, relying on the pressure gauge in the pump, which then stays clean as long as a little air is moving.
John Deere 4455 (A50120)
John Deere 4455...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
2011 Chevrolet Malibu Sedan (A50324)
2011 Chevrolet...
2020 Bobcat S850 Skidloader (RIDE AND DRIVE) (A50774)
2020 Bobcat S850...
