Ballast calcium ballast in tires
   / calcium ballast in tires #11
If a BX2200 has a FEL and 60" MMM will the mower deck act as enough 'ballast'? The mower deck weigh weighs 265 pounds, that seems like quite a bit of extra weight. Can you use the FEL effectively without additional ballast, assuming the mower deck is on there?
I am trying to decide if I need a weight box. Maybe for winter I do need it to plow once the mower deck comes off.
Thanks.
   / calcium ballast in tires #12
wdn, I don't think there's any way of accurately answering your question because it depends on how much weight you're going to pick up in the FEL. For very light loads, you might not even need the MMM, but for heavy loads, it won't be enough ballast.
Bird
   / calcium ballast in tires #13
I've left my MMM on sometimes when using the FEL and it
does act as a good stablizing weight, but not as good as
something on the end of the tractor.
The only problem with leaving the MMM on is that it may
limit your FEL use; I was moving alot of dirt from a big
pile and the MMM would cause problems when I drove
up the pile of dirt. Needed to be careful to not get hung
up on the mower. Basically, the MMM would get in the way.
   / calcium ballast in tires #14
Re: calcium ballast - alternative
Micheal -
The patent for Rim Guard is held by Glen Daly, in Lansing, Michigan (517-351-6470).
I gave him a buzz and he was very helpful. Sent me several copies of the specs on it, and gave me the names of some dealers who are stocking it (not many in my area, since it's relatively new, but I've got my dealer interested). Unfortunately, my tires were already filled when I heard about Rim Guard, so I haven't used it. I have spoken to several people who have, and are happy with their choice.
2021 CATERPILLAR 906M WHEEL LOADER (A52707)
2021 CATERPILLAR...
2006 BMW 325i Sedan (A55853)
2006 BMW 325i...
Honda utv cart (A56859)
Honda utv cart...
1974 John Deere 6030 Tractor (A55315)
1974 John Deere...
2017 Ford T350 Van (A55973)
2017 Ford T350 Van...
2017 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Terex TLM40 Boom (A55302)
2017 RAM 5500...
