Ballast calcium ballast in tires
   / calcium ballast in tires #1
radman
Kubota L3710, JD5300, AC D19, IH 806, IH 8950, Ford 8N, Farmal Super M, several others in the past.
I notice that many tractor owners who use ballast seem to have a distaste for calcium chloride use in tires. I have used it for many years and have not had any problems with rim rust. I do however put rear tubes in all tires with liquid ballast. Yes, it may not be the environmental ideal solution but leaks have not been a real issue in my use. Cost is about $1 per gallon installed. Cheaper than cast iron weights. If tires are changed it can be pumped out and used again.
Any opinions out there? What are cost of other alternatives? Any horror stories? Disasters?
   / calcium ballast in tires #2
Relat: calcium ballast in tires
I haven't had any problems, but I have had second thoughts. I guess my concern was if I ever got a flat tiire with my Calcium filled tires.
   / calcium ballast in tires #3
hello, i considered having calcium chloride in my bx 2200, and was also concerned about leaks and rust and the cost of tubes for the rear tires. i found a auto repair shop that had used auto antifreeze and it was free. i just removed the tires from the tractor and broke one side of the tire from the rim, they're tubless, and put the antifreeze in around the rim, and then aired it up, if i get a puncture, i can just plug the tire since it's still tubless and with the rust inhibitors in the antifreeze, i shouldn't have a problem with rust.
   / calcium ballast in tires #5
Tire Fluids
by Curtis von Fange
It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the way in time to avert a dangerous disaster. So what was this stuff in the tire and why was it there?
Long ago farmers discovered that by adding weight to a tractor certain benefits were recognized. One of those benefits was traction. When pulling implements like a plow or heavy disk through the ground the added drag often caused the tractor tires to spin. By adding weight to the pulling unit the tires could pull more of the tractor weight without loosing the traction. Some farmers installed counterweights on the front of the tractor such as one hundred-pound slabs of steel bolted to the frame. This helped to hold down the front end of the tractor when rear wheel spin would actually raise the front end off the ground due to the implement drag. Others added fluid to the tires. This would increase the overall tractor gross weight which could also increase the amount of draw bar pull by delivering more engine horsepower to the ground through the wheels. In addition the extra tire weight also increased the traction characteristics of the tire by burrowing the tire lugs deeper into the ground with better holding capacity. Fluid added to the front tires helped hold the front end down while pulling large loads, especially on hilly terrain where the front end would tend to bounce off the ground.
The fluid added to the tire inner tubes is simple water. That is why it was so popular to use when extra weight was desirable. Water was cheap and plentiful. The only problem was that it froze in the winter time. In order to keep this from happening the farmer started to add antifreeze solutions to the water. The more expensive types of antifreeze that were used included alcohol and ethylene glycol. These worked quite well but with the potential of running an ever so common briar through the tire and losing the liquid onto the ground a cheaper and simpler solution was used. Calcium chloride became that more attractive solution since it was easily obtained at a cheaper price. It came in powder form and was mixed with water which was then pumped into the standard tire inner tube with a small reciculating pump and valve stem adapter. When a weight mix of 29.8% was used then the eutectic temperature, or the maximum temp that the freezing point of water can be depressed, is around minus 60 degrees Fahrenheit. This type of mix was usually found in most weight based fluid filled tractor tires. Water was put into a barrel or container then the calcium chloride was added and thoroughly mixed. Then the tire was filled from half to three-quarters full, depending on the desired weight to add, then topped off to the standard pressure rating with air.
One negative aspect of using the calcium chloride is that it is quite corrosive. This can be noticed by the corrosion and excessive rusting around tractor rims where the fluid has leaked out of pin holes or leaky valve stems in the inner tube. But with some simple care in filling, repairing leaks, keeping rims primed and painted, and simple washing off of leakage areas this problem can be readily circumvented. Be certain that if the tire encounters a leak that when the tire is removed from the rim it is thoroughly washed to remove the calcium chloride residue. Both the rim, tube and inside of the tire should be rinsed. Another aspect to be aware of is that the extra tractor weight will tend to pull more equipment but it will also sink deeper in soft ground. Yes, the traction will be there but if the soil is too soft to support the total weight the tractor may bottom out on the drawbar and leave the wheels spinning. Either way, be cognizant of the ground conditions before trying to plow, disc, or bushog in wet land.
Calcium chloride is still used in tractor tires today for adding extra weight and traction to the tractor. A tire store that services farm and/or industrial excavating equipment would be a good place to start when looking for a business to fill this need.
~~~from the web~~~
   / calcium ballast in tires #6
If I recall correctly, water is 8 pounds per gallon, and if fully saturated you add about 3 1/2 pounds of calcium cloride, making 11 1/2 pounds per gallon. Methanol is about 6 1/2 pounds per gallon, and you mix one gallon with 6 gallon of water, so a little less than 8 pounds per gallon, for the same volume, you get more weight with calcium cloride. Not sure about car antifreeze.
   / calcium ballast in tires #7
I can tell you unequivocally that after 37.7..no..37.8 hours on my L3010 with calcium filled r4's that I have had absolutely no problems. David
   / calcium ballast in tires #8
Re: calcium ballast - alternative
There is a good alternative to calcium chloride balast: Rim Guard. It's made in part from the juice of sugar beets. Non-corrosive (it actually helps protect rims from corrosion), non-toxic (in fact I believe it's USDA Animal Food Grade Certified), Freezes somewhere below -35F. It weighs about 11 lbs/gallon (heavier than calcium chloride). I THINK it goes for about $1.25/gallon.
   / calcium ballast in tires #9
John_Mc,
Sounds like good stuff. Have you been using it?
Can you tell me where I can find more information on it
or how to obtain some?
Thanks,
Michael
   / calcium ballast in tires #10
Some people would argue that ANYTHING made from beats MUST be toxic.
High techie, reciently founded a startup company and struggling for tractor time.
2016 Laymor SM300 Towable Ride-On Rotating Sweeper (A50322)
2016 Laymor SM300...
2014 Honda Accord (A50324)
2014 Honda Accord...
UNUSED MOWERKING SSECAG-Y AUGER BITS (A51244)
UNUSED MOWERKING...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
UNUSED JCT QUICK ATTACH 74" VIBRATORY ROLLER (A51244)
UNUSED JCT QUICK...
