Cadplans loader
/ Cadplans loader #11
Did you make the hoe from scratch or get the kit?
It looks great!!!
Does it do what the planmakers say it will do?
/ Cadplans loader #12
Hi Everyone, Thanks for the comments on my loader. That is the correct factory color for that vintage yanmar tractor.
As for the price breakdown, I don't have the listing in front of me, however, here it is from memory (approximate):
Hydraulics, from CadPlans/Metkit..........$700.00
Steel and additional hydraulic fittings....$250.00
Paint, Dupont Centari.........................$100.00
I had some custom fittings made in the machine shop where I work at N/C.
Most of the steel was aquired from the scrap bin where my brother works.
There are obviously additional costs in welding, grinding, and shop supplies etc. that were not tracked.
It took two of us approximatly 2 months, nights and some weekends to build.
Yes, a 20 HP would run it, my tractor is a 13 HP diesel, with about 1000 lb machine weight not including loader and added weight.
Hope this answers everyones questions, if not feel free to post more, or email direct (mbrule@rcn.com), I also have many pictures of all phases of contruction.
Matt
/ Cadplans loader #13
That was from scratch. It's using a reclaimed (& rebuilt) 11hp B&G from a leaf blower. The son-in-law worked at a fabrication shop at the time and was able to save a lot from the scrap bins. The only thing I purchased from Metkit was the hydraulics kit. Total investment was maybe $1500. I got away cheap. It does do all they said it would. I've worked it pretty hard.
/ Cadplans loader #14
I like your approach. I have the 907 plans and have started the construction but have had to sidelines things for a while due to lack of time. I am going to buy the basic hydraulics from MetKit (cylinders ,valve and joystick) and get all of the metal locally in Southern Cal. I had the four main boom arm pieces cut at a local shop with an NC controlled flame cutter for $50 and they all came out clean and identical. The rest of the metal parts I can cut with my chop saw or have the scrap yard band saw them to size. I am going to have the hydraulic lines made locally and plan to use rigid steel tubing to each cylinder and then couple to each cylinder with a short flex line. This looks cleaner than using all flex hosing.
/ Cadplans loader #15
Gerlacr:
That is very similar to what I did as far as the steel. I like the idea of the steel tubing for the hydraulics, will probably cost a bit more, but will be a lot better looking!
Matt
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
STORAGE FEES (A59908)
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
John Deere 652R 52in Stand-On Commercial Mower (A56857)
John Deere 652R...
set of 4 tractor trailer tires Roadforce (A61307)
set of 4 tractor...
207283 (A52708)
207283 (A52708)
