Cadet 7260 Air Filter Replacement
   / Cadet 7260 Air Filter Replacement #1
JRobyn
Elite Member
Middle TN
Kubota L4330HST
Hi guys,
I read several threads on here and elsewhere about trying to find a replacement for the OEM air filter on my FIL's Cub 7260 without much success. The Cub part, p/n MA-1031051120, is stupid expensive, $121. Wix cross-references this to their p/n 46483, which is NOT the correct replacement because it is missing the metal end cap. Some said that a Wix 46387 was the replacement, but this one, while it has the correct style, metal end cap, and even the plastic "turbo sleeve", is way too short at only 7-3/8". The OEM with the end rubber gasket mashed down after years of use is about 10-1/4" long.
WIX/NAPA had a very close candidate in p/n 46496/FIL 6496, but the price of that was still $65.
By persistent web sleuthing, involving searches and leads and links that I have now forgotten, I arrived at a Donaldson P535362. Only $30.63 from FilterPros.com. This one is ALMOST exact!! The major difference is that the OEM has a LARGE hold down wing-bolt hole of about 5/8" to fit the strange wing bolt (see photo), and the ID is slightly larger than the OEM. But with a bit of step-drilling on the new one for the wing bolt it fits and works perfectly. The plastic "turbo sleeve" can be easily slid off the OEM, cleaned and reinstalled on the new one. It's a tiny bit longer, but I think this is all due to a fresh unsquished rubber gasket.
If you drill and use one of these be very observant for any metal shreds or burrs left inside from the drilling. See last photo - this came from INSIDE where it would have been ingested!!
I have sent Donaldson a message with photos to see if they happen to have anything that would fit exactly with no modification at all and will post back here if they do.
Photos attached that are all self-explanatory.
SANY1557 (1024x768).jpgSANY1558 (1024x768).jpgSANY1559 (1024x768).jpgSANY1560 (1024x768).jpgSANY1561 (1024x768).jpgSANY1562 (1024x768).jpg
P.S. FilterPros also had the correct p/n 33264 fuel filters for $5.83 ea versus $15.30 ea from Cub Cadet.
- Jay
   / Cadet 7260 Air Filter Replacement #3
to update as the filterpros website is long dead but, the air filters are still out there..... The fuel filter on the other hand... is still a cub cadet only option as the wix/napa options are all ~1/8 to 1/4" to tall. unless the filter bowl i have is the wrong size by previous owner behavior.
the Donaldson is on amazon for $36 plus shipping
there is a Lube-finer that is also on amazon for $39-ish
here are the respective pages with spec info.... i will let you find them on amazon.
Donaldson P535362
Attributes
Outer Diameter 4.09 inch (104 mm)
Inner Diameter 2.48 inch (62.9 mm)
Length 10.13 inch (257.3 mm)
Overall Length 10.51 inch (267 mm)
Bolt Hole Diameter 0.27 inch (6.8 mm)
Efficiency 99.9
Efficiency Test Std ISO 5011
Primary Application KUBOTA 1574111080
Type Primary
Style Round
Media Type Cellulose
LAF8823 by LUBER-FINER - HD Air Filter
Specifications
Spec. Value
I.D. Top: .28 [7mm]
Height: 10.43 [265mm]
I.D. Bottom: 2.48 [63mm]
O.D. Top: 5.91 [150mm]
O.D. Bottom: 4.09 [104mm]
Application: Kubota 15741-11080, Komatsu 3EB-01-25830; Kubota B2150 B9200, PX2100 Tractors
Buyers Guide: Kubota 15741-11080, Komatsu 3EB-01-25830; Kubota B2150 B9200, PX2100 Tractors
Product Description Luber-Finer Air Filter LAF8823
   / Cadet 7260 Air Filter Replacement #4
I can confirm that the NAPA fuel filter is 1/8" too tall. That's running a new filter bowl too, so it's not just your machine.
1964 Mercedes-Benz 190D Car Sedan (A56859)
1964 Mercedes-Benz...
Blue Diamond 403010 3pt 4' Mower (A56469)
Blue Diamond...
Black Metal Roof Panels (A55758)
Black Metal Roof...
2016 KENWORTH T660 SLEEPER TRUCK (A58214)
2016 KENWORTH T660...
GROUNDHOG ZH12G EXCAVATOR (A57192)
GROUNDHOG ZH12G...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
