cadet 1730 barely moves in reverse
   / cadet 1730 barely moves in reverse #1
rvds
Platinum Member
montreal qc
mf 135
Is this a common problem with hydrostatic transaxles?
   / cadet 1730 barely moves in reverse #2
Hydrostatic transmission on a lot of mowers and tractors are factory set to move slower in reverse vs going forward but should have similar tractive effort in both directions.
yes but this one has no power at all in reverse.
   / cadet 1730 barely moves in reverse #4
Granpa backed up and ran his grandchild through the mower deck and parents sued. So, deck turned off and turtle reverse.
   / cadet 1730 barely moves in reverse #5
No power in reverse is not normal. Have you confirmed that the reverse linkage is intact and rotating the control shaft? Forward linkage rotates shaft one direction, reverse opposite direction. Since that tractor is getting older has the linkage worn or is something blocking the movement.
That model might have relief valves for forward and reverse. Possible reverse relief is stuck open.
Thanks, will see the tractor soon and check that.
UNUSED FUTURE FT380 STAND ON SKID STEER (A57192)
UNUSED FUTURE...
John Deere 6170R (A53317)
John Deere 6170R...
Enmark Z Spray (A53316)
Enmark Z Spray...
UNUSED FUTURE FT-46 1230MM HYD MULCHER (A57193)
UNUSED FUTURE...
Carnival Ticket Booth (A51691)
Carnival Ticket...
2015 Ford F-350 4x4 Cab and Chassis Truck (A53422)
2015 Ford F-350...
