Caddy Fuel Pump Question
   / Caddy Fuel Pump Question #1
NCMau
NC
MF 202/Ford 8N
I bought a new 12V, 30 gal gas caddy fuel pump while back. It worked for few weeks then quit. I put it aside, then lately I decided to take a look. The pump is fitted with a welded 3/4" suction pipe into the caddy. The output hose is 5/8".
The voltage is from a good battery and electrically the pump seems to be turning at the right speed (it is not laboring).
I checked and rechecked any possible air leaks in the suction.
I opened the plate to check the rotary vane, it seems to be turning fine.
Put few drops of oil in it , still no gas coming up.
There are about 5 gal of gas in the caddy.
Opened a plug where there is a spring (pressure relief valve?) I am not sure what am I supposed be looking at.
I don't know what else to do I would be very grateful for any words of wisdom.
   / Caddy Fuel Pump Question #2
Have you ever had the level that low when you started pumping before? You didn/t state what brand or quality you have, but it may not like to start a suction at low levels. Probably don't want to hear this but I would get it filled and try again.
Thanks for the reply. I decided to open and explore the pump area and the only thing I saw out of place was the bypass valve (a plastic sleeve) that wasn't seated properly. So, I re-seated it and it works fine.
I do have another question though. During the process of troubleshooting, I reversed the wiring polarity to see if the motor was incorrectly wired. The motor worked fine and reversed the fuel flow back into the tank. This is desirable feature that I didn't even know was available because it was not mentioned in the two-page manual.
My question is: is it safe run it backward? Do you guys do it?
   / Caddy Fuel Pump Question #4
1*This is desirable feature that I didn't even know was available because it was not mentioned in the two-page manual.
A Caddy is for transferring fuel not storing it.
1*I can do the same with this storage rig with out reversing the pump
I usually fill 25-25 gal in my 30 gal caddy, so the storage time is not very long. (Definitely not longer than a month).This caddy allows me to fill my tractor and lawnmower a lot easier and spill-free.
It is not clear in the pic how you accomplish fuel reversal without reversing the pump. Could you elaborate please?
   / Caddy Fuel Pump Question #6
I do reverse the wiring on my pump also. Allows me to suck fuel oil out of 250 gallon tanks for people who have changed over home heating. I usually get both the oil and the tank for free. So far every one is happy.
   / Caddy Fuel Pump Question #7
I wouldn't think you would hurt a thing. I would be a little careful not to suck in something from the bottom of a tank.
   / Caddy Fuel Pump Question #8
It' was easy I just teed in an extra hose to the pick up
side of the pump and used a couple of ball valves to switch things back and forth ..
2006 FREIGHTLINER CST120 TANDEM AXLE SLEEPER TRUCK (A54607)
2006 FREIGHTLINER...
2015 KENWORTH T270 SERVICE TRUCK (A51406)
2015 KENWORTH T270...
2007 FORD F650 XL SUPER DUTY FUEL & LUBE TRUCK (A51406)
2007 FORD F650 XL...
2018 Yamaha 48 Volt Drive 2 Golf Cart (A52377)
2018 Yamaha 48...
UNUSED EINGP F10 - 10' WROUGHT IRON SITE FENCE (A54757)
UNUSED EINGP F10 -...
2016 Ford Taurus AWD Sedan (A53424)
2016 Ford Taurus...
