CAD Digger Bushings - Brass vs Nylon??
   / CAD Digger Bushings - Brass vs Nylon?? #21
McMaster-Carr sales all types of bushing and there not that price.mcmaster.com and search bushing.
   / CAD Digger Bushings - Brass vs Nylon?? #22
I have built several 700 series CAD paln backhoes for 3 pts and another smaller version hoe from another plan and found that cost and use the green and white plastic nylon with oil impregnation is just as good and if not better than bronze. I got the idea from a manufacturer who uses the green for bushings in a large 100 ton machine. Does last without grease and most definately longer than bronze. Bad news is that it is very pricey even in the 2 " diameter. I have had one in my hoe for 6 years and no slop or any visible wear.
   / CAD Digger Bushings - Brass vs Nylon?? #23
I owned a cad digger for somewhere around 4-5 years. I put 100's of hours on the machine and only replaced the bushings once, just because.
I bent pins but never a problem with a bushing.
Those backhoes are crazy strong for a backhoe of any size much less their small size.
I wish my Kioti hoe used the same bushings the caddigger did, those things were super easy to replace the one time I did replace them and they were inexpensive and very very durable.
I am a huge fan of caddiggers, amazing little machines.
With those bushings there is little chance of reaming out any metal parts, in theory the friction points just won't wear out.
Related question, why are there not bushings on equipment where the cyl attaches?
Joel
   / CAD Digger Bushings - Brass vs Nylon?? #24
Thanks Kim
That is pretty impressive. I have ordered the bushings from MetKit. After discussing this (ad nauseum according to my wife /w3tcompact/icons/laugh.gif) with my buddy who's shop we are using to build this digger, we decided to go this route. If they don't last we do have the facilities to change them fairly easily.
Thanks to everyone for their outline of experience sprinkled with an appropriate dollop of skepticism - a pretty good mix I think.
Bob
From my experience with the machine you've made the right decision.
Joel
   / CAD Digger Bushings - Brass vs Nylon?? #25
Note that there is a difference between nylon and nylatron. Nylatron is harder with a higher yield point. It machines better too. Of course, it's more expensive.
   / CAD Digger Bushings - Brass vs Nylon?? #26
Check out IGUS bushings. Take a look at this site
igus - iglide plastic bearings to replace bronze bushings
I used them in several industrial design projects and have been sold on them. Some times you can talk the sales person in to supplying you with samples to try.
One drawback is that the bores for the bushings have tight tolerances and they have to be pressed in.
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A56857)
2007 Godwin Pumps...
2000 JLG 800A TELESCOPIC/SCISSOR BOOM LIFT (A52709)
2000 JLG 800A...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
WELCOME CONCRETE STATUE (A58374)
WELCOME CONCRETE...
2023 Isuzu NPR S/A Dump Truck (A56858)
2023 Isuzu NPR S/A...
