cad cabet 2164 fuel in oil
   / cad cabet 2164 fuel in oil #1
redlake
I am getting fuel in my oil. Where is it comming from?
   / cad cabet 2164 fuel in oil #3
What motor? If you have a gravity fed carb; the float can stick and fuel will normally drip out of carb; but it could go into crankcase via breather bypas or valve guides.
   / cad cabet 2164 fuel in oil #4
   / cad cabet 2164 fuel in oil #5
Yes, it's probably a worn or sticking carburetor float needle/seat that is flooding the engine internally with gas when it it shut down. This can occur regardless if the fuel is gravity fed or if the engine has a fuel pump. Most modern small engines on LGT's have an electric solenoid at the carb that shuts off the fuel flow to the carb when the ignition is off to prevent this, but I think that's after the time of the 2164.
The flooding gas works its way into the oil just as dqdave1 described.
-Fordlords-
   / cad cabet 2164 fuel in oil #6
-Fordlords-
WHISPERWATT DIESEL POWERED GENERATOR (A53843)
WHISPERWATT DIESEL...
2018 INTERNATIONAL LT625 (A53843)
2018 INTERNATIONAL...
2017 Chevrolet Express 2500 LT Passenger Van (A51692)
2017 Chevrolet...
2019 MACK PINNACLE (A53843)
2019 MACK PINNACLE...
2016 Suzuki King Quad 500AXI 4x4 ATV (A51694)
2016 Suzuki King...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
