cad cabet 2164 fuel in oil
   / cad cabet 2164 fuel in oil #1
redlake
I am getting fuel in my oil. Where is it comming from?
   / cad cabet 2164 fuel in oil #3
What motor? If you have a gravity fed carb; the float can stick and fuel will normally drip out of carb; but it could go into crankcase via breather bypas or valve guides.
   / cad cabet 2164 fuel in oil #4
   / cad cabet 2164 fuel in oil #5
Yes, it's probably a worn or sticking carburetor float needle/seat that is flooding the engine internally with gas when it it shut down. This can occur regardless if the fuel is gravity fed or if the engine has a fuel pump. Most modern small engines on LGT's have an electric solenoid at the carb that shuts off the fuel flow to the carb when the ignition is off to prevent this, but I think that's after the time of the 2164.
The flooding gas works its way into the oil just as dqdave1 described.
-Fordlords-
   / cad cabet 2164 fuel in oil #6
-Fordlords-
2006 BIG TEX 16 T/A TRASH TRAILER (A53843)
2006 BIG TEX 16...
1994 Prevost Liberty Coach 40FT T/A Class A Motorhome (A51694)
1994 Prevost...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A53424)
2004 Fleetwood...
SET OF (6) LADDERS (A53843)
SET OF (6) LADDERS...
1990 Nitro Tracker 165TF Bass Boat with S/A Galvanized Trailer (A51694)
1990 Nitro Tracker...
