cabin air filter on 99 f350
   / cabin air filter on 99 f350 #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
getting ready to do a service on my 99 f350 ( door date tag of 12/98 )
I see i have any of 3 possible filter combinations for the air filter with 12/98 as the to/from dates. :)
dealer did my 1st service when i got her, and my local mechanic did my last service when i had a water pump replaced. I do my own servicing on my 6.0psd and will now start on the 350 and 450 when she is due.
aside from the air filter.. which i see i will need to pull and match up..
oil filter is easy.. it's a 1734.. and down by the pan.. etc.. got the copper 14mm washer for the drain plug...
now... cabin air filter? does this model have one? i see 4 listed on the napa site after plugging in all my trucks data, including vin digits it asked for.
if it has them.. is it a passanger inside area by your feet like in some gm trucks, or the pita under the plastic cover by the windshield wiper deal?
thanks
6484 airfilter.. that was easy.. :)
now just to find out about the cabin air filter..
   / cabin air filter on 99 f350 #3
I have a '99.5 since new and not aware of it having a cabin air filter in it.
There were multiple engine air filters and a least one TSB was issued to correct a problem. I know first hand a my airbox was changed out and the air filter went from approximately 1" thick to about 2.5" thick.
ist went out and looked some more.
I can't find hide nor hair of a cabin fitler.. looke dunder the ww wipers.. and over on pasanger side is just the cowling etc.
my 450 is a 99.5 and has a different air box than this early 99. this one has the filter that is about 1.5" plus a foam prefilter pad that is another 1" thick on it.
my 04 250 has a different box from new and now uses a 9490 element in it.
the 450 has yet another one..
gotta love it. :)
thanks for the double check man.
another funny thing.. from early 99 to late 99, the early doesn't have a cruise lamp on the dash 9 well.. it's there it just doesn't lite up.. whereas the late one does. i read someewhere you can change out a ecu and get the lamp.. but seems spendy for a lil lamp to tell me i'm not touching the throttle.. :)
thanks
   / cabin air filter on 99 f350 #5
I am pretty sure it does not have a cabin filter.
Chris
   / cabin air filter on 99 f350 #6
No, you don't have a cabin air filter. Us Ford guys get our air raw, all natural. LOL
Just a suggestion, but have you considered a K&N air filter? They cost about twice as much as a paper filter, but last a lifetime. Just wash, dry, and re-oil.
I have them in all my trucks, as well as my motorcycle.
the 450 has a k&n box in it, mind you it never see's off road, only road miles.
2021 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A50323)
2021 Toyota Tacoma...
2017 MAHINDRA MAX26XL TRACTOR (A51243)
2017 MAHINDRA...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
2017 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2017 PETERBILT 579...
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
