Cab with a 3050?
   / Cab with a 3050? #1
AKfish
Super Member
Alaska
JD 5115M; JD 110 TLB; JD 4720; Ford 9N; JD X300R
The NH dealer has a pretty good reputation among the local farmers in my area. And, I'm seriously considering moving to a cab tractor in the next year or so.
I'd like to learn more about the NH lineup.
But, I'm a bit confused by the NH website's technical specs for the new Boomers. When you work your way down the list; in one or two categories it appears that the cab option is available with the 3050 tractor.
However, when you reach the transmission options and the associated specifications - it sure looks like the cab option is NOT available with the 3050.
What's the real story? Also, I can't seem to figure out how to find/review the loader models and their specs.. Sure would like to know what loader models are available and how they stack up against the competition.
Thanks for help/feedback.
AKfish
   / Cab with a 3050? #2
The specs show an iso-mount cab but the brochure says the cab: "SuperSuite comfort Available on four models葉he
Boomer 3040, 3045, 4055 and 4060"
   / Cab with a 3050?
Appreciate the info, thanks.
Looks like I'd have to go with a hyd shuttle if I want 50hp+ and a cab.
AKfish
   / Cab with a 3050? #4
I wouldn't necessarily recommend it(out of not knowing their performance), but JD has a 50+ hp hst in their biggest CUT's.
Chris
   / Cab with a 3050? #5
There is a cab available on the 3050 with the CVT transmission. There is no cab on the 3050 gear tractor. There is no 3050 HST.
The loaders for the 3040, 3045 and 3050 are the 250TL for the standard steer front axle and the 260TL for the supersteer front axle (extra clearance for the pivoting axle). The tech specs for the loaders can be found on NH's site here.
   / Cab with a 3050?
OK.. that's were I fell off track - HST vs CVT!!! :confused: When I worked my way down the tech sheet on the NH website; I saw a cab option listed for the 3050. Then further down the sheet, I found "N/A" for both the gear tranny and the HST. Guess I just didn't study it hard enough...
Thanks for the link for the loaders. Appreciate it.
Gotta do some homework on the CVT transmission, now. Sounds a bit like the IVT transmission that JD offers in the 6000 premium series (7000, too) tractors.
AKfish
2013 International DuraStar 4400 Altec AM547 50FT Material Handling Insulated Forestry Bucket Truck (A51692)
2013 International...
2013 GMC Yukon Denali 4x4 SUV (A51694)
2013 GMC Yukon...
U56 ELECTRIC FIRE PUMP (A51406)
U56 ELECTRIC FIRE...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2016 RAM 3500 HD SERVICE BODY TRUCK (A52576)
2016 RAM 3500 HD...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
