willysmb
Bronze Member
I have read many threads on cab vs no cab and the basic consensus is that if you can afford a cab you should get a cab. My question is, if the primary use for a tractor was going to be for around the home would a cab be annoying? I plan to use the tractor mostly around my yard and shop and also on a hunting property. Although it will get used at the hunting property a couple times a month it will mostly be used at the house.
Around the house: Moving pallets, assisting with vehicle work (lifting motors, moving axles, etc), landscaping, garden etc. A lot of these tasks are going to require a lot of on and off the tractor which is making me thick a cab could get annoying.
Hunting Property: Food Plots, landscaping/ponds (puddles/watering hole), wood cutting, etc.
I do have a need for snow removal but I can snowplow with my Jeep. I have a few acres of fields to do. I would like to expand upon this but nothing is in the works now so I can't really plan for it. My thought is that I would maybe be better off to go with a smaller tractor now and a second larger cab tractor later if my need for field work ever increases beyond the couple acres of field work I have now.
