cab roof removal
   / cab roof removal #1
trilly
anybody know how to remove roof on jd 4720 cab to clean evaporator?
   / cab roof removal #2
I'll guess the thirteen nuts(parts key 14) must be removed to raise roof. I know a lot of long screws around perimeter of my Kubota have to be removed to raise it's roof.
   / cab roof removal #3
I raised the roof on my Branson. Being alone I had to improvise. I have a covered parking area where I park my balers. I made it tall enough to accept my JD 530 which rolled a 5x6 and my 4230 (100 hp) with cab both of which I have sold and replaced with smaller equipment.
The Branson is only 65 hp and compact so the top of the cab is lower and easily fits under the cover with room to spare.
I removed the 4 bolts holding it in place and through the holes, I tied 4 ropes that I had attached to the purlins on the cover. Little bit at a time, going around it and working it on up and out of the way so that I could drive out from under it and do what I had to do.
Something like that might work for you.
Mark
   / cab roof removal #4
Can ayone given me the instructions to remove the roof on a 5220C Branson 2015.
I removed the 6 nuts and grommets from the top but it won’t budge.
Thank you in advance.
LOAD OUT AND SHIPPING (A51572)
LOAD OUT AND...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
New/Unused Two Post Car Lift 10,000lbs (A51573)
New/Unused Two...
2014 Ford Taurus AWD Sedan (A51694)
2014 Ford Taurus...
New/Unused CFG Industrial QK18R Mini Excavator (A51573)
New/Unused CFG...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
