Cab Heating Options
/ Cab Heating Options #11
/ Cab Heating Options #12
Another option could be something like the Coleman Golfcat 3000 btu heater found here:
Amazon.com: Coleman GolfCat Perfectemp Catalytic Propane Heater: Sports & Outdoors
You'd likely have to fashion an appropriately size cupholder (pvc pipe would work) and affix it to the cab frame but by all accounts they work quite well.
Before I put the cooling system heater in cab I used the Coleman Golfcat 3000 btu heater . Lot better than having nothing in cab . Made a hanging bracket and used it today in the wifes gator. Outside temp was high teens , but with heater and enclosed cab went for a 2 mile ride .
/ Cab Heating Options #13
I have a hard Curtis cab on my Bx with the standard coolant heater. To beef up the inside heat I added some foam sheet insulation to cover outside air leaks and added a RoadPro ceramic heater (300W). Cab is now very comfortable at all winter temperatures.
/ Cab Heating Options #14
I plumbed engine coolant using hosing and copper piping to a core that is mounted near cab ceiling above the loader valves thus blowing hot air downwards towards the feet.
The heater core (carter 6 x 6) was salvaged from under rear seats of an old scrapped school bus. Since it was 6 volts at origin I used a 12v computer muffin fan to propel the hot air, the muffin fan being very compact and drawing a mere 1 amp.
Has worked like a charm for about 8 years now.
Being high and out of the way it also keeps the windshield frost free. Moving hot air will do that.
For my rear window another but 3" computer fan mounted on a magnet allows me to position for best effect and naturally it 'grabs' hot air and clears the back window which when blowing snow at -20 or so is a necessity.
/ Cab Heating Options #15
12V electric heat is a daft idea.
Plumb the hot water heater supply line from just under the thermostat. Return the water to the water pump inlet.
We see questions here from people plumbing the heater lines from the side of the block and head like a tank water heater. Then they are baffled why the heater doesn't work.
/ Cab Heating Options #16
you can get a regular radiator or hyd oil cooler. and connect into the coolant lines running to/from the radiator on the tractor.
BUT, you need to make sure you put in some way to "purge" air from the extra lines that run into cab. ALSO highly advised placing these purge air valves outside the cab, so ya not smelling antifreeze inside the cab.
you can just get some sort of 12V fan, that plugs into cigarette lighter and place behind the radiator/hyd oil cooler that ya turned into a heater. have seen many folks use a computer case fans, Newegg.com - Computer Parts, Laptops, Electronics, and More! tends to have a fairly large selection of computer case fans. most of the fans come with min of 2 wires, some times 3 wires, find a computer case fan that has 2 wires to make electrical easier.
folks have hit salvage yards to get various radiators, hyd oil coolers, and/or heater cores. some have poped the dash off of a vehicle, and just took the heater core from a vehicle.
would forget idea of insulation, and just go for fan blowing heat. and then make sure you can plug up all the "air gaps" were air can move in and out of the cab. removing them air gaps can be a big plus, in keeping heat in the cab. just be carefull of not breathing hyd oil, and like and keep oil cleaned up so ya not breathing it.
Pace American MW8516TA2 T/A Enclosed Concession Trailer (A56857)
Pace American...
Takeuchi TL6R (A60462)
2020 Kubota RTVX1140 (A60463)
2020 Kubota...
2016 New Holland Boomer 47 (A60462)
2016 New Holland...
(3) Good Year 480/80R38 Tires w/ Rims (A60463)
(3) Good Year...
CFG H15R (A60463)
CFG H15R (A60463)
