Cab Heater Airlocked ?
   / Cab Heater Airlocked ?
Hey guys,
I said I would report back. Deon, I think your are not far off in something not installed properly. I am open to feedback here. When I installed the adapter (spacer with the hose connection on the side of the adapter)on top of the motor where the thermostat is. I removed the thermostat housing left the thermostat and placed the adapter on top of the thermostat and the housing on top of the adapter. I believe I should have placed the thermostat on top of the adapter instead of under it. Someone can correct me if I am wrong but I don't believe I am getting the full pressure to the heater hose for circulation. The adapter can be seen (if this works) in the attachment (the installation instructions I got from Sims Cabs) when you schroll down to the very last page. Thanks
Kevin
  • Mounting Instructions Kioti CK25HST[1].pdf
   / Cab Heater Airlocked ? #12
From the steps on page 13:
  1. Drain coolant from engine
  2. Remove top of thermostat housing
  3. Remove thermostat
  4. Install street elbow into collar
  5. Install collar with gaskets and shut off valve
  6. Re-install thermostat and housing using:
It would appear that you need to put the new adapter on, then install the thermostat on top of it. This will give you more coolant flow and will let you get heat even when the thermostat is closed
Aaron Z
Your right Aaron. Just a matter of following/carefully reading the instructions step by step ! Got heat and lots of it. Thank you everyone for all the help. Certainly a learning process for the do it yourselfer.
Kevin
1992 CATERPILLAR 14G MOTORGRADER (A52709)
1992 CATERPILLAR...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
Atlas Copco XAS90JD Portable Air Compressor (A57453)
Atlas Copco...
2017 BX2680 Sub Compact Utility Tractor (A56435)
2017 BX2680 Sub...
John Deere 7230 131HP 4WD Agricultural Utility Tractor (A56857)
John Deere 7230...
2022 Ford F-150 XL Pickup Truck, VIN: 1FTFX1E88NFB23656, Extended Cab, 4 x 4, 3.5 L EcoBoost Gas (A59076)
2022 Ford F-150 XL...
