Snow Cab Heat
   / Cab Heat #11
I block off the lower half of my radiator. Before that I couldn't get my tractor up to temperature but now the engine warms up nicely and so does the cab.
   / Cab Heat #12
If your wife sews, you could get her to make a fitted blanket for the whole tractor hood. Maybe out of old blankets or something insulated. It is very effective and with just a bungie cord underneith, easy to take on and off. Diesels use a lot of air and don't warm up well in the cold.
   / Cab Heat #13
What about a block heater. In conjunction with covering the radiator some?
   / Cab Heat
I got it figured out, I moved the cardboard down to the bottom, and actually cut some back which, and it's been blowing a nice temp.
   / Cab Heat #15
Yup, cardboard does the trick. I am in my first winter with the Emax 25 cab and up here anything about -8C and colder it dos not like at all. I could not get to proper PTO RPM's and it would spew a stinky white smoke and it sounded very tinny. And as you said the cab heat was just warmish. So I tried covering 3/4 of the rad with card board (i think about -18 that day). Let it run for a bit and went to blow and wow what a difference. The cab nice and toasty, no white smoke at high RPM and the engine sounded 100 times better (normal).
It is warmer now so I need to be aware of how much rad i cover but so far no issues.
Other than that do how do you like the tractor?
2023 TAKE 3 TRAILER 3 CAR TRAILER (A52141)
2023 TAKE 3...
John Deere 843 Corn Head (A50514)
John Deere 843...
2007 JOHN DEERE 310SJ BACKHOE (A50458)
2007 JOHN DEERE...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2022 BOBCAT T595 SKID STEER (A51242)
2022 BOBCAT T595...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
