Cab and heat for the BX2350
   / Cab and heat for the BX2350 #1
PA-Kubota
Apollo PA
2008 BX2350
I'm getting older and like warm things now. Who sells a heated cab or has plans so I may make it?
   / Cab and heat for the BX2350 #3
   / Cab and heat for the BX2350 #4
I always like to go low tech and el cheapo when possible. Get yourself a cab and then look at heaters for golf carts. They are gas heaters that run on little LP tanks. I just saw one listed on a golf site for $80. That might be the ticket. In reality, a cab really raises your surrounding air temp without any heat. I find that most times in my cabbed B3030, I turn the heat off because I'm too hot.
Good luck.
   / Cab and heat for the BX2350 #5
Do a forum search and you can find a number of options. There's essentially a few different cab options available in the US/Canada from Laurin, Sims, Jodale Perry, and Curtis. The Curtis cab is probably your cheapest option. (If you're based in Europe, then other options exist.)
Here's a good starting thread with pictures of several of the cabs installed on the BX2350:
http://www.tractorbynet.com/forums/kubota-owning-operating/114242-bx2350-24-laurin-cab.html
Tektite (out of Canada) - makes a pretty slick looking cab for the BX tractors also.
ROPS Tractor Cab Manufacturing by Tektite
2008 OVERLAND TANK KILL TRAILER (A52472)
2008 OVERLAND TANK...
2019 Dodge Challenger GT AWD Coupe (A51694)
2019 Dodge...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2011 JACK  130BBL (A52472)
2011 JACK 130BBL...
INOP/NON-RUNNING Chevrolet Rollback (A51572)
INOP/NON-RUNNING...
2018 Sakai SW990-1 Tandem Vib Roller (A52384)
2018 Sakai SW990-1...
