Cab and heat for the BX2350
   / Cab and heat for the BX2350 #1
PA-Kubota
Apollo PA
2008 BX2350
I'm getting older and like warm things now. Who sells a heated cab or has plans so I may make it?
   / Cab and heat for the BX2350 #3
   / Cab and heat for the BX2350 #4
I always like to go low tech and el cheapo when possible. Get yourself a cab and then look at heaters for golf carts. They are gas heaters that run on little LP tanks. I just saw one listed on a golf site for $80. That might be the ticket. In reality, a cab really raises your surrounding air temp without any heat. I find that most times in my cabbed B3030, I turn the heat off because I'm too hot.
Good luck.
   / Cab and heat for the BX2350 #5
Do a forum search and you can find a number of options. There's essentially a few different cab options available in the US/Canada from Laurin, Sims, Jodale Perry, and Curtis. The Curtis cab is probably your cheapest option. (If you're based in Europe, then other options exist.)
Here's a good starting thread with pictures of several of the cabs installed on the BX2350:
http://www.tractorbynet.com/forums/kubota-owning-operating/114242-bx2350-24-laurin-cab.html
Tektite (out of Canada) - makes a pretty slick looking cab for the BX tractors also.
ROPS Tractor Cab Manufacturing by Tektite
2011 Autocar ACX64 Xpeditor coe t/a refuse (A52384)
2011 Autocar ACX64...
Massey Fergusson 4253 (A50120)
Massey Fergusson...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
CFG Industrial MH12RX (A50121)
CFG Industrial...
2022 McConnel TRAXX RC28 Remote Controlled Slope Mower (A51691)
2022 McConnel...
Unverferth Model 1225 Double Rolling basket (A52349)
Unverferth Model...
