c5264 Cofle joystick problem
/ c5264 Cofle joystick problem #1
riverhino
Letts, Iowa
I have a Cofle joystick that I need parts for - any idea where I can find this stuff or even a diagram on how to separate the controller from its casing?
The curl cable connects to a piece of plastic which in turn connects to the joystick itself - and the plastic "piston" sheared right where the metal cable rod ends.
Any ideas appreciated - this is a Koyker loader mounted on a c5264 Montana.
(love the tractor - not impressed with Cofle joystick engineering).
thanks
-Ryan
Turns out the plastic part is a molded part of the cable itself.
Koyker's Service and Warranty dep't has me fixed up with a replacement cable and direction on how to do it - quick shipping and a fairly reasonable price on the cable ($77).
Still not thrilled with the plastic - maybe I'm just old-fashioned but I like steel!
/ c5264 Cofle joystick problem #3
riverhino, can you take the Old Cable to a machine shop and have a metal version of the plastic piston made/attached? then you have another spare incase cable number 2 gives out.?
/ c5264 Cofle joystick problem #4
Hi, I have the same problem, got the replacement cable from NH, but need directions as to how put it on. Thanks
24in. Bucket w/ Teeth Excavator Attachment (A64194)
24in. Bucket w/...
(4) 10-16.5 Tires (A65640)
(4) 10-16.5 Tires...
Skeleton Backing Plate (A62679)
Skeleton Backing...
Concrete Mixer (A62613)
Concrete Mixer...
Skid Steer Blank U-Plate (A65640)
Skid Steer Blank...
2008 Ledwell LW48HTHT2 48ft. 40 Ton Hydratail T/A Step Deck Trailer (A64194)
2008 Ledwell...
