C4005 fuel tank drain
   / C4005 fuel tank drain #1
hose6161
lone star, texas
c4005-di
Mornin folks. I am going to replace the fuel tank drain,gasket, and bolt on my C4005 because the gasket was shot and I noticed a piece of teflon tape hanging down from the drain-to-tank threads(i couldn't actually see the connection due to FEL and chassis.)Questions--Should I use teflon tape on the new connection? Will I have to drain and dry the fuel tank 1st? The service manual is no help(Looks like it was written for a politicion).
   / C4005 fuel tank drain #2
I don't like using teflon tape on anything hydralic, or fuel lines. You have a fuel strainer and fuel filter in between your tank and your injection pump. But any little piece of teflon tape that gets into something like that raises *&%^(*& with it.. I'd use some Permatex on the threads... Good luck, Jerry
2017 Peterbilt 567 Day Cab (A52384)
2017 Peterbilt 567...
2012 Honda Pilot SUV (A51694)
2012 Honda Pilot...
UNUSED CFG INDUSTRIAL QH12R EXCAVATOR (A51247)
UNUSED CFG...
250 GALLON FUEL TANK (A51247)
250 GALLON FUEL...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
