BXxx50 Battery Cover: New or Old?
   / BXxx50 Battery Cover: New or Old? #1
MoreCowbell
Clayton, NC
Kubota BX2350
I know there have been a number of threads regarding the redesigned BXxx50 battery cover. However, I could not find what I was looking for, so here is my thread.
My BX2350 is 18 months into the 2 year warranty. The sides of my battery cover don't exactly fit well but don't constantly flop out of place either like with some folks, so I am wondering if I have the old or new one. :confused:
I know the new part # is K2581-57134, however, I could not find anything stamped onto my battery cover. From what I hear the old and new ones are very similar visually. Is there any way to tell them apart? If I have the old one I would like to hit up the dealer for the new one under warranty before it expires. Thanks!
   / BXxx50 Battery Cover: New or Old? #3
... one other thing. I did see a post http://www.tractorbynet.com/forums/kubota-owning-operating/221750-plastic-front-end-fix.html#post2537297 by Thavil showing a retrofit kit for the battery cover. Is this what I should be seeing or does Kubota have a replacement other than this retrofit kit?
Thanks again.
Follow this thread and you will see the two bracket part #'s that I bought after Thavil showed me my tractor had them missing. I bought the new cover (mine had the ears busted off) and the two brackets...walla!! A MUCH nicer fit!!:thumbsup:
Deano
Thanks for the reply Deano. Those retrofit brackets look nice and it sounds like they do the trick. In my case though, I am still under warranty, so if Kubota has a fix for it that they cover under the warranty, I'd like to make sure I get that.
However, if it turns out that my battery cover is the redesigned one, I probably will spring for the brackets just to stiffen the thing up.
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2024 Greatbear 72in Vibratory Roller Skid Steer Attachment (A51691)
2024 Greatbear...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
2005 Ford F-250 4x4 Reading Crane Service Truck (A51692)
2005 Ford F-250...
2012 Mack GU713 T/A Gardner Denver Kill Truck (A52377)
2012 Mack GU713...
