BX7326 Rear Aux. Kit (install)
   / BX7326 Rear Aux. Kit (install) #1
actionaj
Southern Illinois
BX2350
This weekend I installed the BX7326 Rear Aux. Kit on my 2350. This kit is very well made and very well designed. It was relatively an easy install probably taking 40 minutes at most. I only had two minor problems with the install. The first one is the bolt supplied with the kit to hold the valve onto the side of the transmission is wrong. The bolt supplied with the kit is a 12mm it should be an 8mm bolt. The 12mm bolt won't go through the valve and the boss on then side of the transmission is 8mm, no big deal. The second one is indexing and tightening the fittings on the valve before installing (per-instructions). You will need to leave the fittings slightly loose to line up with the steel lines. After all the lines are started, tighten down the fittings. This takes an assortment wrenches and crows feet line wrenches. Again no big deal.
This kit is very well designed the all the lines run nice and tight to the sides of the transmission. Operation of the levers is convenient and smooth. The QDs are in a good location to.
All I need now is to order a set of male QDs and top link cylinder.
Here are some pictures of the install.
More pictures.
   / BX7326 Rear Aux. Kit (install) #3
Wow! Thanks for the pictures, and words about the remote install. That is one slick looking installation. I wonder if there is a kit for my B2620 like that? I would think that you have more than doubled the usefullness of your set up with that addition. Keep us possted on how it works out, and thanks again for the great pics of the install.
   / BX7326 Rear Aux. Kit (install) #4
Hi
Judging by where the levers go that would be where my existing cruise control lever is located
I guess this kit would only fit the BXxx50 series then
Correct?
Regards
DGS
   / BX7326 Rear Aux. Kit (install) #5
I think they have a kit like this for most of the tractors these days. Chuck, there is a blank off plate on your 2620 on the ride side just behind the cruise control and 3PH 1/4" valve controls. I think that plate is for the location of these 2 control valves.
My B3030 has a similar setup, and I am thinking strongly about putting it on my tractor, even though I don't have an immediate need for it.
I have seen a few setups that people have done with "surplus" parts, and you can get more capability for less money than the Kubota setup, but I personally am somewhat partial to the level of integration of the factory setup...
   / BX7326 Rear Aux. Kit (install) #6
Wow that's a nice looking set up. I hope the one the dealer is installing on my new B7800 looks that good. :eek:
   / BX7326 Rear Aux. Kit (install) #7
Wish I could find a mechanic that did work as good as you do. Your bench looks like an operating table.
   / BX7326 Rear Aux. Kit (install) #8
Ah, you are right, there is a blank plate just above the 1/4 inching valve. I'll have to see what that set up costs for my tractor.
   / BX7326 Rear Aux. Kit (install) #9
What do you plan on running with your new remotes?
First I am planning to get a hydraulic top link. Then add a pivot cylinder to my blade. From there the possibilitys are endless.
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
City of Buckhannon - 2000 GMC 3500 Service Truck (A52384)
City of Buckhannon...
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
2014 Ford Escape (A50324)
2014 Ford Escape...
2024 Kubota L3302 4x4 Tractor with Backhoe (A51573)
2024 Kubota L3302...
2014 TEXAS PRIDE GOOSENECK (A52472)
2014 TEXAS PRIDE...
