BX5100 shifter knob
   / BX5100 shifter knob #1
freefour
Southern IL
Kioti DK40SE HST
My Dad bought a new shifter knob for his BX5100 (old one is in really bad shape). Does anyone know how to get the old one off? Even the dealer had no clue. Thanks!
   / BX5100 shifter knob #3
Can you tell how the new one fastens on? That might give you a clue how to remove the old one.
   / BX5100 shifter knob #4
you mean for bx1500? which shifter knob? speed? pto? 3 pt?
   / BX5100 shifter knob #5
If it's a pressed on knob, just heat the shaft with a propane torch as close to the knob as you can get, usually takes just a minute. Since you've got a new knob, you're probably not worried about the old one, but if you wanted to save it, just wrap a wet rag tightly around it, paying close attention to the underside, then heat away The new knob needs to be seated on a heated shaft, so work quickly and get one off, the other on as fast as you can.
I'm not sure, it's my Dad's. It's a 50 horse tractor. He just order the knob and we're waiting to get it in. We can't figure out how to take the old one off in the meantime. It's the gear shifter knob. Thanks
   / BX5100 shifter knob #7
I can't add any advice, but I think it may be a MX5100?
   / BX5100 shifter knob #8
Yep, I don't think there's any 50 hp machines in the BX line...... unless The Fred has been working on them! LOL
Sent from my iPad using TractorByNet
Industrial Air Contractor Air Compressor (A51573)
Industrial Air...
2016 Ford F350 - Butler Bale Bed - 4WD - 125k Miles (A53472)
2016 Ford F350 -...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
2025 New/Unused Wolverine Hydraulic Skid Steer Pallet Forks (A51573)
2025 New/Unused...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
