Bx42r and a kubota l45
   / Bx42r and a kubota l45 #1
andrehoude123
I just got a used bx 42r chipper For a tractor a have a Kubota l45 so with ports to I put in my 2 hoses and also I don't know witch hose is in or out on the chipper there is no coloured ends and they just leave from the hydro pump
   / Bx42r and a kubota l45 #2
My guess is that you have two power hoses and one tank hose. Just got to figure out who's who. On the chipper your motor will need to feed in, that's how I think you will find out that side. JJ?
   / Bx42r and a kubota l45 #3
Hi Andre
You might want to search the threads for "L45" and "M59". I say something recently about someone who did not have the rear remotes on their L45 or M59 but had been able to use the backhoe hydraulics to power his attachment. I believe you have the three lines for the hoe are two supply lines - one for the swing pump and one for all the other backhoe functions and a single return line.
Sorry I can't be of more assistance.
Regards,
Lauren
Thanks guys I if probably want to plug in my line on the Main line not the swing eh? Would probably work better
So after reading this thread I guess I'll just plug it into my main port how would I know the temperature?
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2014 Ram 1500 4x4...
Manac Walking Floor Trailer (A50322)
Manac Walking...
2007 Hino 268 Truck, VIN # 5PVNJ8JT072S50704 (A51572)
2007 Hino 268...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
