BX2750D Snowthrower operational questions...
/ BX2750D Snowthrower operational questions... #1
Jabroni
Central MA
Kubota BX24
I mounted my new snowthrower to my BX24 today. I have a couple of questions with regards to its operation.
1) Is it best to allow the snowthrower to "float", or should down pressure be applied?
2) When the snowthrower is engaged, it's pretty noisy while it's running. I don't think there's any binding as I have no problem turning the output shaft by hand. Does this sound normal? This is a brand new unit.
/ BX2750D Snowthrower operational questions... #2
I keep mine in float to follow the contours of my drive. There is a certain amount of noise generated by the blower but when your blowing snow it quiets down some.
/ BX2750D Snowthrower operational questions... #3
If have a gravel drive, you will probably find that it is best to keep the blower off the ground just a little until you get hard base of snow built up for it to run on.
It is hard to tell about the noise, but blowers are generally pretty quiet. If it is new to you, but used, I would look for a bent shaft. A bent shaft could be causing a chain to go tight and slack, which would make some noise (just a guess).
It's an asphalt driveway, and the unit is brand new.
By the way, it was very easy to install, and I should be able to easily switch out the snowthrower for the plow when I have to.
The only thing I don't like about it is the rinky dink way they secure the manual chute rotation crank. On the BX, an "eye" is secured to the loader control shaft to support the long control shaft. When you rotate the crank, the loader handle wiggles back and forth and overall is pretty shakey. The kit came with mounting hardware for other tractor models, and that stuff appears a lot more substantial. A bit of grease on the worm and teeth on the chute makes it much better, but in retrospect, I should have sprung for the rotation option. Wonder if it's retrofittable?
/ BX2750D Snowthrower operational questions... #6
Just recently installed my new BX2750D on my BX2360 and also noticed a fair amount of noise. I thought it was coming mainly from the chain area. TBN members assured me it was normal. I did adjust the chain tension to specs when I found it was as tight as a banjo string and that quieted it down a little bit. May just be the nature of the beast.
/ BX2750D Snowthrower operational questions... #7
If you apply any downpressure, you will immediately eliminate your steering!!!
/ BX2750D Snowthrower operational questions... #8
Jabroni, the manual crank chute grows old fast. Last winter was my first with the 2750D blower and I ended up holding the joystick steady with my left hand while turning the crank with my right. If I didn't do this I would find myself raising and lowering the blower while I cranked. This year I have made 2 modifications. I added a hydraulic chute rotator (copied from Dyer, retired) and new skids. The chute rotator cost about $200 to do. I live on a gravel road and my driveways are gravel and I was throwing a lot of rocks until I got a good base. I found the OEM skids only allowed about 1/2" of height adjustment so I made some new ones from ultra high molecular weight polyethylene. It's just a very dense plastic which is workable like wood; you can cut it, rout it, even drill and tap it. Anyway, it's very slippery and wears well. I made these 1 in. thick and bolted them to the bottom of the OEM skids. I had the material for the skids, but McMaster-Carr carries it. Now I'm waiting for snow to see how they work. Photos of the chute rotator and skids can be found at the end of my Kubota Gallery.
/ BX2750D Snowthrower operational questions... #9
dsmiley, real nice setup for the motor on the rotator. You dont have a part number on the motor?? Vendor where it was purchased ?? Was the motor mount bought or fabricated ?? How did you cut the extra teeth in ?? Thanks
Are there stops to the chute rotation, or can it go round 'n round in one direction?
/ BX2750D Snowthrower operational questions... #11
There are no stops; it can go around and around. I cut nine extra teeth in the chute because I didn't want an Oops moment when it got to the end of the travel, and it can go in either direction. I will be answering Keyman's question on how I cut the teeth later.
/ BX2750D Snowthrower operational questions... #12
Keyman, the motor was purchased on ebay. It was a new Anchor Lamina A62FM with foot mount. As others have said, it doesn't make a lot of difference what hydraulic motor you get because there are no real torque demands here; the smallest will work so I looked for a small one that didn't have a high max. rpm. I have seen videos where people have done this mod. and when rotated the chute would scream around. What they need is a hydraulic restricter in the line. Anyway, the one I bought has a max. rpm of 982 and it has turned out to be a good speed. If I had to go one way or the other from this I would choose a little slower.
After purchasing the motor I went about making a mount. I copied what "Dyer, retired" had done only used different materials. I used the same two existing bolt holes for the vertical piece where I used 1 sq. tubing and then made a horizontal piece template out of 1/4" plywood. When the template shape suited me I copied it to a 1/4" thick piece of steel plate. I then cut a piece of steel rod for a brace. I took it all to a local welder who welded it all up in less than 5 min.
I measured up the chute flange and entered the measurements into a CAD program which showed that 9 more teeth could be added with even spacing between all teeth. I printed this scale drawing and transferred the critical points to the chute flange. I then drilled out the base of the tooth valleys with a drill size with the correct radius (don't recall the size but close to 1/4" diam.). After drilling the holes I cut the sides of the teeth into the holes completing the tooth profile. I used an electric die grinder with a slitting disc but a hack saw would work fine here.
/ BX2750D Snowthrower operational questions... #13
In my experience, the front blower is a bit louder when raised than when lowered. I suspect this is due to the angle of the PTO shaft. There are also two holes on the quick hitch for the lift cylinder, only one of which should be used for the front blower. Either position can be used for the front blade. My dealer set it up in the wrong position, which I corrected. I have hydraulic rotate, which was pricey but so worth it.
/ BX2750D Snowthrower operational questions... #14
I had the exact same experience today as you and others with the snow blower. I've had the BX 2360 since May and other than the noisy transmission I'm happy with the operation.
I mounted the bx2750D blower today and unfortunately my dealer had not serviced prior to delivery. No oil in gear box, the vent plug was still painted over and no lube on the grease fittings. I pulled the cover on gear reduction cover and lubed the chain and also found out the chain was as tight as it could possibly be. It was still quite noisy when I engaged it so I ran the blower for about 30 minutes. That did seem to help. But the noise is still predominant.
I have a Woods sb52 on my old kubota B7200 and it does not make anywhere near as much noise as the new bx2750D. But I'm looking forward to clearing our 1000' drive by driving and looking ahead for a change.
I do see some other ideas hers for raising the skids also possibly adding a power chute rotator. Thanks for that input.
I'm sure the noise won't be noticeable when we fill the auger with snow that will add it own audio. Have fun.
This is my third Kubota I purchased in 25 years, also have a B3030 with LA 403 loader and MMM.
/ BX2750D Snowthrower operational questions... #15
I also got frustrated with the whimpy manual chute rotator and converted to a hydraulic motor this summer. There is a thread in the hydraulic section on DIY flow restriction, http://www.tractorbynet.com/forums/2113172-post32.html. This was a simple and easy solution to slow down the speed of the chute rotation. Looking forward to our first lake effect snowfall later this week.
/ BX2750D Snowthrower operational questions... #16
The noise is normal. I should know, Ive had two brand new units :eek:
/ BX2750D Snowthrower operational questions... #17
The quick connects for the hydraulic lines, are they available only from kubota or are there aftermarket ones?? think I have eveything I need but the quick connects. Just need them and the hose to complete my parts list then off to build. Anyone know ??
/ BX2750D Snowthrower operational questions... #19
Keyman, if you are going to cut the extra teeth I would be happy to send you a pdf file of my CAD drawing. If you can get the scale to 1:1 using a copier or something you can cut out the paper, lay it on the flange, and prick-punch the hole centers. It looks like I used a 19/64" drill to make the extra holes.
Dean
/ BX2750D Snowthrower operational questions... #20
Thanks Wild Bill that was the last info I needed. Just ordered all the parts and hoses. Now I need to built the mounting bracket and I should be done. I am still debating if I will cut the extra 9 teeth in still.
Honda 300 Four Trax (A61166)
Honda 300 Four...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
UNUSED KJ 45'X25' DBL GARAGE STEEL BARN SHED (A62131)
UNUSED KJ 45'X25'...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
KSI Conveyor (A63118)
8086 (A61165)
8086 (A61165)
