BX2750C Snowblower Questions
   / BX2750C Snowblower Questions #1
x703jko
Maryland
Kubota BX24TLB
Ok...embarrasing newbie questions...
1) How do I check the oil level in the drive box?
2) How do I access the chain to lube it?
Jeff
   / BX2750C Snowblower Questions #2
Jeff,
Drive box, you should have two bolts, one on top and one on the bottom of the drive box, about an 1-2" apart, take the bottom bolt out, if lube comes out it is full.
Chain lube: A hole is on top of the chain guard, place oil in the hole and the oil will land on the chain. I use a pump oil can with a flexible nozzle works great.
If u need pictures let me know I will take some in the AM.
NY_Yankees_Fan said:
Jeff,
Thanks. I think I'll be ok. I'll let you know if I need to see a pic.
Jeff
   / BX2750C Snowblower Questions #4
I think N Y Yankees Fan meant to say take the TOP bolt (screw) out and see if fluid trickles out.
Never remove the bottom bolt to drain until you are sure the top bolt will loosen.
2004 TRAVIS BODY & TRAILER DOUBLE ALUMINUM BELLY DUMP COMBO TRAILER (A58214)
2004 TRAVIS BODY &...
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58216)
RIPPER ATTACHMENT...
2001 Ford Explorer SUV (A56859)
2001 Ford Explorer...
Hustler super Z zero turn (A56859)
Hustler super Z...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
