Snow BX2750B allen set screw on socket won't stay...
   / BX2750B allen set screw on socket won't stay... #1
SailTrac
On the shores of Lake Ontario in the heart of Lake
BX2200
If you look at the owners manual, page 28, reduction box assembly. the sprocket keeps backing off. I have reset the allen set screw as tight as I can but it's not holding. Its done it 3 times in a row. bit of a PITA with this snow storm...
So I know one of you guys will know why it keeps coming loose and what I'm doing wrong.
Thanks,
Mike aka SailTrac
   / BX2750B allen set screw on socket won't stay... #2
Without having the diagram to refer to, would it be possible to put a second set screw on top to lock it in? I've seen this done on pulleys where there is enough thread depth.
Another solution might be to replace it with a NAS bolt with a head drilled for safety wire if there is no interference issues.
   / BX2750B allen set screw on socket won't stay... #3
OR.. a drop of Lock-tite.?? Blue is service removable.. Red takes a torch/heat to remove it & Green is on there.. forget about removing it.
   / BX2750B allen set screw on socket won't stay... #4
OR.. a drop of Lock-tite.?? Blue is service removable. Red takes a torch/heat to remove it & Green is on there.. forget about removing it.
YES!!!! Have parts grease free before applying thread locker.
   / BX2750B allen set screw on socket won't stay... #5
I'll second the recommendation for Loctite or similar thread locker. It's not clear to me what the part is to which you are referring, but I'd be inclined to use the blue loctite (removable). I've had good luck with it, and not having to use a torch to get it apart is a plus, in my book.
Blue Loctite does keep the set screws in place, however even with Loctite and as much force as I can with the allen wrench, that upper sprocket keeps creeping/walking to the back of the shaft.
This time it threw the key. Luckly I had a 1/4 roll pin that I could jury rig, till I can buy the correct key.
This blower is testing my mechanical skills, and right now it's kicking my butt.
   / BX2750B allen set screw on socket won't stay... #7
Most set screws have a cup point that locks the set screw in place. Once that gets worn a set screw may no longer hold and needs to be replaced. It seems you may have reached the time to replace the set screw.
   / BX2750B allen set screw on socket won't stay... #8
Has it always had this issue or is this a recent development? Without a setscrew how is the fit of the sprocket on the shaft? If it is a sloppy fit that could be part of it. Without the key in place I would check to make sure the hole for the setscrew is freely open to the shaft. The thought being the setscrew hole threads might be damaged at the bottom and the screw is bottoming out on damaged threads instead of the key.
Doug in SW IA
   / BX2750B allen set screw on socket won't stay... #9
The setscrews purpose is to increase the friction between the bore and the shaft. Poor fitting or worn parts that move under use defeat the friction. Should be two setscrews at 90 degrees apart. Blue Loctite helps threaded fasteners. There is loctite (660)for retaining press fit parts and worn parts. There are also knurled cup point setscrews that resist backing out. Have come across some soft (counterfeit?) setscrews so make sure using quality ones. Good luck!
   / BX2750B allen set screw on socket won't stay... #10
If you are using a simple "L" shaped allen wrench, you may not be able to tighten the setscrew to the proper torque. A set of allen head sockets is better for the job:
https://www.amazon.com/Craftsman-Ev...t=&hvlocphy=9007140&hvtargid=pla-569926731581
If possible, determine the factory spec and use caution to avoid over torquing.
(3) Rolls of New Barb Wire (A50515)
(3) Rolls of New...
2019 Harley Davidson (A50324)
2019 Harley...
197359 (A50458)
197359 (A50458)
Grady-White 17ft Fishing Boat with T/A Boat Trailer (A50324)
Grady-White 17ft...
John Deere 335 Round Baler (4ftx4ft) (A52128)
John Deere 335...
2025 Swict 60in. Bucket Skid Steer Attachment (A50322)
2025 Swict 60in...
