BX2660 - what is this part?
/ BX2660 - what is this part? #1
psvines
Earlysville, VA
Kubota BX2660
I found this piece of metal on my driveway today after driving over it with my BX. Is it from my Kubota?
Thanks for the help.
Further inspection, one end is clearly broken. Plus there is NO dirt or grease on it.
/ BX2660 - what is this part? #2
It reminds me of the cable tension spring from a hand winch, but it looks thicker. I don't remember it on a BX.
Bruce
/ BX2660 - what is this part? #3
I agree with bcp. Check the parts diagram but don't think this is a tractor part.
/ BX2660 - what is this part? #4
Never saw anything like that on my BX2660.
/ BX2660 - what is this part? #5
Just a thought; Check the tension latches on the air cleaner housing.
/ BX2660 - what is this part? #6
I'm thinking that is some kind of body part that retains the hood/body area. Have you recently removed the front panels?
/ BX2660 - what is this part? #7
I can't ID it either (from memory). If you have done some maintenance of recent, I'd look over all that you handled.
Using a detailed parts diagram, I think it is part of the support for the air filter. Part # K2551-82150.
Thanks for all the suggestions.
/ BX2660 - what is this part? #9
this is half [probably the half that is nearest the side bonnet of the air cleaner support bracket [part # K2551-82150], not sure why they break probably vibration from the diesel engine but I used zip ties to secure my air cleaner to the rest of the bracket. Plan to weld the two halves of the bracket sometime in the future [late fall/early winter] when it is a more convenient time to work on.
/ BX2660 - what is this part? #10
Its the tension shim from the foldable ROPS.
/ BX2660 - what is this part? #11
Did the BX2660 ever get a folding ROPS?
I thought that started with the 70 series.
It looks similar to the MMM height adjuster tension band that keeps the knob from spinning.
/ BX2660 - what is this part? #12
Don't know about all of them, but my BX2660 does not have a foldable ROPS.
2019 CATERPILLAR 239D3 SKID STEER (A60429)
2019 CATERPILLAR...
(INOP) 2012 CATERPILLAR 324EL EXCAVATOR (A60429)
(INOP) 2012...
2014 JLG 6036 6,000lb 4x4 Rough Terrain Telehandler (A59228)
2014 JLG 6036...
2007 Ford F-150 Ext. Cab Pickup Truck (A59230)
2007 Ford F-150...
2006 KOMATSU PC228USLC-3 EXCAVATOR (A60429)
2006 KOMATSU...
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
