bx2660 tiller size
   / bx2660 tiller size #1
Maestro71
Ohio
Kubota bx2660 loader mmm back blade woods rotary cutter
Is it possible to run a 60" tiller on a bx? Or am I asking for trouble?
   / bx2660 tiller size #2
I have a 40 inch one and probably could of went to a 60 inch , because I have never bogged down engine of my BX2660 . I suspect the only factor to check about using a 60 inch one would be weight of the unit compared to three point lift specs. But tillers (at least the residential or medium grade ones) are pretty light attachment anyway.
my vegatable garden is only 24 x 24 so a no need to spend money on bigger tiller .
   / bx2660 tiller size #3
I "believe" the manual recommends against anything over 42", but I use a 50" on our BX2200 as well as BX2660, I doubt power would be an issue in fairly soft ground, wet ground bogs mine down some.
Thanks for the info guys, I am looking at a used king kutter 60" for 900$ otherwise i would go smaller but it seems like a good deal.
   / bx2660 tiller size #5
While the BX has a Cat 1 3PH, the geometry of some Cat 1 implements don't fit well on them due to the small size of the BX. Several makers including KK make products designed for use on a SCUT.
   / bx2660 tiller size #6
I'll just give you my experience and you can judge. I have a L2800 and use a 48" King Kutter which is the size recommended in the book. I have a mixture of sandy and clay dirt and when its a little bit wet it will bog down my tractor.
   / bx2660 tiller size #7
We run a 60" on our B7500 which has less power than the BX2660. IMO, if it will run a 60" mower in heavy grass, it should be fine (power wise) with a 60" tiller.
Geometry may be another story, but power shouldn't be an issue.
Besides, you have HST, so you can go as slow as you want.
Aaron Z
2025 New/Unused Wolverine Pallet Fork Frame with Forks (A51573)
2025 New/Unused...
Kubota BX23 4x4 Backhoe (A51573)
Kubota BX23 4x4...
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
1997 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
1997 HEIL TRAILER...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2018 John Deere 8270R MFWD Tractor (A53342)
2018 John Deere...
