LostInTheWoods
Platinum Member
While running the rotary cutter today, I noticed the throttle lever felt loose compared to the way it normally feels. I also noticed the RPM's start to slowly creep down. Needless to say, it got to be a little aggravating holding the throttle down while using the tractor.
After a search here, it would appear that I need to find a "throttle lever friction adjustment" - most likely a nut needs to be tightened.
Its dark outside now, but I need to get back at it tomorrow afternoon. Anyone have any suggestions/advice...is it easy to find and adjust on the BX's? Anything else I should consider in the event that doesn't fix the problem?
