BX2660 Idle Speed
/ BX2660 Idle Speed #1
Fxfymn
Fredericksburg, VA
Kubota L4060 HST, FEL; Kubota BX2660
BX2660 Idle Speed??
My recently delivered BX2660 has an idle speed of 1450 RPM which seems a bit fast when I turn the key off. The dealer told me that Kubota does not specify a min/max idle speed and the BXs they have sold have idle speeds ranging from 1000 to 1450.
For all you BX2660 owners out there-What does your BX2660 idle at and have you had it changed since you took delivery?
/ BX2660 Idle Speed #2
Mine is around 1380. I thought it was a little high but have not changed it. I'm curious to know what others are too.
/ BX2660 Idle Speed #5
I would have to check as I never "idle" except to bring it down and immediatelty shut it down; too much shaking at idle for me. I run it just fast enough to smooth out.
/ BX2660 Idle Speed #6
The higher idle speeds may have more to do with tier 3 compliance then anything else, low idle engines run colder and do not burn as clean.
David Kb7uns
/ BX2660 Idle Speed #7
Finally checked as I got a little tractor time today, looks like mine is at the low side per responses, at 1250 +/-
/ BX2660 Idle Speed #8
Mine is about 1400 give or take a few, i too was curious when i first saw it but i looked in the kubota manual and it emphasizes a target rpm, i do not remember what that is but i do know that my rpm is normal for the 2660 so it shouldnt be anything to worry about
/ BX2660 Idle Speed #9
My BX24 is right at 1450 since new. Seemed high to me at first is also, but nice and smooth at that rpm; the only shaking is right as it starts and when I shut it off. Since the tach is electronic, variations seen might but in the method of getting the reading rather than the true engine rpm. It is most important to pay attention to the RPM required for proper PTO speed (it's in your manual).
/ BX2660 Idle Speed #13
Darn, I only remember to check my BX2660 idle when I'm online. I guess I need wifi on my Bota.
/ BX2660 Idle Speed #14
/ BX2660 Idle Speed #15
David Kb7uns
This makes total sense to me. My guess is that emissions are the reason we see the increases in rpm for rated hp and the 540 PTO output. I think some of the new smaller engines are rated at 3000 rpm or higher?
/ BX2660 Idle Speed #16
Dont forget the timing has been advanced to reduce the emmisions :mad:
and that has huge part in the shake rattle and roll as well as the high and low idles.:mad:
/ BX2660 Idle Speed #17
Our '09 BX2660 idles at 800-900 RPMs, but shakes the whole tractor doing it.
You don't get any aux (3 point, loader, etc) hydraulics until ~1350 RPMs.
Aaron Z
/ BX2660 Idle Speed #18
The BX's shake the hood quite a bit at idle. I wouldn't be surprised if the dealers turn them up just enough to alleviate the rattling.
/ BX2660 Idle Speed #19
Since new (now at 250 hrs) it idles cold or hot @ about 1400 rpm (+/- 50), and shudders rather violently when turned off:confused3:.
JOHN DEERE 8400R TRACTOR (A64280)
JOHN DEERE 8400R...
5000 GALLON WATER TANK W/RELEASE VALVE (A64280)
5000 GALLON WATER...
SIDE STEPS FOR 2009 TAHOE (A64281)
SIDE STEPS FOR...
PALLET OF PLASTIC BREAD BASKET (A64281)
PALLET OF PLASTIC...
2007 John Deere 1790 Planter (A63111)
2007 John Deere...
UNUSED WOLVERINE 3PT QUICK HITCH (A64281)
UNUSED WOLVERINE...
