BX2660 BLADES
   / BX2660 BLADES #1
mlange2009
Any body know what size socket it takes to take the blades off my BX2660 THANKS
   / BX2660 BLADES #2
If you own a metric machine, then you need to buy a quality metric socket set. In Canada Metric is slowly taking over. I am fighting thou.
Craig Clayton
   / BX2660 BLADES #4
I'm just guessing you meant 13/16 size socket? 3/16 would be really small.
   / BX2660 BLADES #5
30MM is what I used with an air impact wrench.
   / BX2660 BLADES
that's the answer i was looking for 30mm thanks
   / BX2660 BLADES #7
1 3/16ths will do, but prefer the 30mm if you can find it.
2008 IC Corporation PB205 Bus, VIN # 4DRBVAANX8A506494 (A51572)
2008 IC...
2019 D&P WELDING  12FT LUBE TRAILER (A52472)
2019 D&P WELDING...
2000 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
2000 HEIL TRAILER...
2020 COLOMBO TM LOT NUMBER 215 (A53084)
2020 COLOMBO TM...
2012 Ram 3500 Chassis Pickup Truck, VIN # 3C7WDTAL9CG134341 (A51572)
2012 Ram 3500...
2008 Chevrolet Impala Sedan (A51694)
2008 Chevrolet...
