BX2660 and R1 Tires
   / BX2660 and R1 Tires #1
tjl5709
Unit came with R4's. Bought a set of turfs for cutting lawn and pushing snow as chains mounted better on them. When I do FEL work, I mount the R4's. That said, they clog up. Thinking of going to R1's to replace the R4's as I have some major dirt moving to do.
Can I use the same rims?
Tire / brand to look at?
Same size as the R4's?
Exploring options. Thanks.
   / BX2660 and R1 Tires #2
You will need different rims, or so I was told. I have them on my BX2200.
   / BX2660 and R1 Tires #3
Same wheels, same tire sizes between r1 and r4 on the bx
   / BX2660 and R1 Tires #4
Do you know to go to the Kubota salesman and buy from the wholegoods book it will be cheaper then from parts department. You get tire and wheel ready to install.
   / BX2660 and R1 Tires #5
I bought a full set of R4's with rims for my last BX2660. $300 from the dealer. For me, it was a waste. I wound up using one set of tires for the term I owned the tractor.
   / BX2660 and R1 Tires #6
R4's have a much higher load rating than R1s. Not sure if that will matter on a tractor as small as a BX, but it is something to check before you commit and find out they pop the beads under load or roll off the rim when turning with a load. If that sounds like experience, it is...
30FT REDROCK BOLSTER (A48992)
30FT REDROCK...
More info coming soon! (A46683)
More info coming...
4 IN WATER SPRINKLER (A48992)
4 IN WATER...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
8 Titan Bush Hog, 3pt hitch, PTO  (A47371)
8 Titan Bush Hog...
Massey Ferguson 275 2WD Tractor (A49251)
Massey Ferguson...
