bx25d noise from front u-joint?
   / bx25d noise from front u-joint? #1
frogpond
Snohomish WA
Kubota BX25D
When going in reverse, or sometimes when turning sharply in forward, and especially with a load in the loader bucket, I hear an intermittent clunking noise from somewhere up front. The only strange thing I find easily is that there is a shiny bare spot that has been scraped on the yoke holding the drive shaft universal joint. It's on the part attached to the shaft, not the front axle. I can see it because the plastic sleeve over it got broken a few months ago (probably by some debris on the ground--this tractor spends a lot of time in the woods). I called my dealer's service department about the sleeve, and they said not to bother replacing it, as I would have to disconnect the shaft to do it, and it;s really not a necessary item. It's not clear to me what the u-joint yoke could be hitting, or, for that matter, if that's what is causing the sound. I keep the tractor in 4wd all of the time--lots of loader work, and steep and muddy conditions.
I have checked the oil in the front axle, and it's okay. I'm pretty religious about greasing, too. There's no debris stuck in there. I see that one of the tie rod boots has recently ripped, but I haven't yet had time to replace it. I wonder if tire pressure could be affecting things.
The tractor has about 620 hrs. on it. I had the 400 hr. service done at the dealer.
I would appreciate any thoughts that might shed light on the matter.
2019 Nissan Frontier SV 4x4 Ext. Cab Pickup Truck (A48081)
2019 Nissan...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A50397)
80in HD Tooth...
2023 Chevrolet Tahoe SUV (A48082)
2023 Chevrolet...
2014 CHEVROLET SILVERADO 1500 (A48992)
2014 CHEVROLET...
2014 Chevrolet Silverado 2500HD Knapheide Service Truck (A48081)
2014 Chevrolet...
2016 Ford Focus SE Sedan (A48082)
2016 Ford Focus SE...
