Hey Guys
Just a after a bit of advice before I have to call the dealer (who I have next to no confidence in)
I have 2 leaks on my relatively new (30 hours) BX25D - this (red) fitting on the return (?) line from the loader ram has just started leaking:
I'm not quite sure how that fitting works, is it simply a matter of tightening it? It's a bit hard to tell, but I think it may be leaking from the crimped part. Is that sort of thing covered under warranty? The dealer is about an hour away don't want to get them out if it's just a nip up with the spanner that's required...
Also I got a 60" mmm deck with the tractor which I used for about 30 seconds to test it, then not too long ago removed from the tractor and it's just been sitting (flat) in the shed. The other week I discovered a pool of hydraulic (?) fluid under it. Being a tractor newbie I didnt even realise the deck contains oil so I cleaned it up and thought it must have come from the fluid I spilled when pulling out the mesh hydraulic filter in the transmission to check it for blockages - my BX25 gets the terrible squealing noise after it gets hot
That's yet another problem... anyway within a few days the pool of fluid was back, so it's obviously leaking out of the deck somehow - from the underside it looks like as I can't see anything coming from the top... again is this just a case of new deck something not tightened properly or does it need to go in for warranty repair??
If I get the dealer out is 30 hours close enough to 50 for the initial service or would you suggest I wait until the 50??
I haven't exactly had a good run with this tractor so far, but I absolute love it and am finding I'm using it a lot more than I even expected to.
