BX25d FEL Float?
   / BX25d FEL Float? #1
Johnkn
Platinum Member
Laplata, MD
Kubota LX3310
Greetings, does the new BX25 have a float function? If so, how does it work? I saw mention of it in the manual, but could not find mention of how to put the bucket in float. Thank you...
   / BX25d FEL Float? #2
Probably by pushing the lever forward till it stops, then push it farther, and it will snap into float position and stay. It helps to try it with the engine off until you get used to it.
Bruce
   / BX25d FEL Float? #4
Push the stick forward, 12:00. Then push again, and you will feel a click. You can practice, by leaving the bucket off the ground. Then push forward to the click and watch the bucket drop.
   / BX25d FEL Float? #5
Push hard forward on the stick and it will go into float or it's tore up. Some people do it in two steps or movements but you don't have to. Just push it hard forward. You may "feel" the two positions but you don't have to do them.
   / BX25d FEL Float? #6
what i do is push it forward till it seems to stop and give it a nice short "snap" forward past that resistant force. I love the float mode, i use it in so many situtations, i just dont think about it. i just use it when needed.
   / BX25d FEL Float?
Thanks all...
   / BX25d FEL Float? #8
That's called a "detent" in the valve when you push it all the way forward into float.
   / BX25d FEL Float? #9
Yep! that's how it's done.
   / BX25d FEL Float? #10
My bad, wrong info 12:00. Getting older and bad memory :ashamed:
2014 FREIGHTLINER M2 TANDEM AXLE 24FT FLATBED (A50046)
2014 FREIGHTLINER...
2021 CATERPILLAR 289D3 SKID STEER (A50458)
2021 CATERPILLAR...
2022 Chevrolet Tahoe SUV (A48082)
2022 Chevrolet...
2007 KOMATSU WA250-5L WHEEL LOADER (A50458)
2007 KOMATSU...
2018 Ford F-550 4x4 Summit 4416 Crane Mechanics Truck (A48081)
2018 Ford F-550...
KUBOTA L39 BACKHOE (A50458)
KUBOTA L39 BACKHOE...
