macguyver13
Hi all,
I'm still relatively new to this tractor stuff (but am loving it so far). Recently I bought a 3PH log splitter and hooked it all up to the back of my BX25 using the hydraulic connections used by the 3PH itself when the backhoe is not attached. I run the short hydraulic hose to the splitter and from there back to the inlet port on the tractor. That has allowed me to raise/lower the splitter (the splitter is open center) while it is attached. I have used it a couple of times now and it worked great (if a little slow due to gpm of BX25 but fine with me).
However, the last time I tried it I was moving a pallet with a bit of wood on it using forks on my bucket (thanks BXpanded) which was fine except that I noticed that when I lifted the bucket with the load on it, the log splitter started moving on its own! Under very little load it is fine, but if I have to fully deflect the FEL control to get it to raise, the splitter starts moving (as if to split wood, not retracting).
Now I'm new to the hydraulic game, but if it's an open center valve, shouldn't the fluid just flow through the splitter (no matter what PSI) and back into the tractor? Why would additional pressure trigger the valve to move one way (and not the other)?
Hoping I haven't done anything that seriously injures my tractor, but I'm wary to use it again until I have an idea what's going on. Any ideas?
Thanks in advance for helping me out even if it's just to set me straight on the hydraulics (again, just using the connections used by the 3PH on the BX25, not the 3rd inlet which returns to the reservoir I believe).
