BX25 Transporting
   / BX25 Transporting #1
DC3
Bronze Member
PA
What deck length would I need for a trailer to haul a BX25?
What's the minimum, and recommended, GVW capacity would I need for a trailer?
Thanks!
   / BX25 Transporting #2
I use a tandem axle 18' dovetail car trailer for my GC there is enough room to haul my rotary cutter with it too.
   / BX25 Transporting #3
Thanks!
Most of the guys here use double axle car type trailers of flatbed type with two 3500 pound axles with electric brakes... 16 or 18' in length... this way you are good to go for just about anything...
I towed my BX 23 400 miles with a heavy duty single axle equipment trailer with a 5000 pound axle... the deck was 10' plus the area on the V tongue hitch where the bucket was chained down... it just fit with not an inch to spare.
If money is no object... some use aluminum trailers to save weight on the tow vehicle.
7000 GVW trailers are pretty common.
   / BX25 Transporting #4
I just use a single axle 16 ft trailer. Not the best.
   / BX25 Transporting #5
I would recommend at least a 16' trailer with dual axles. 7K weight. I bought aluminum because I don't want to buy another one in the future.
   / BX25 Transporting #6
I've towed my BX23 on a 14' tandem trailer and it barely fit. Doable, yes, recommended, no...16' would be much better...18' is ideal for centering the load.
Weight shouldn't be a problem on any tandem trailer. Brakes are needed as this weighs probably 2500# with everything attached.
I wouldn't try trailering a BX2** with a single axle utility trailer.
   / BX25 Transporting #7
I use a 16ft dual axles trailer without brakes, now for my BX23, but looks like I am going to have to move up, as I am getting a B3200 Turbo, got to ask Devildog1 about the Turbo, its on the hood. I should get a 18ft dual axle with brakes next, I think. The main thing is to chain the tractor down good, and make sure your hitch chains are crossed under the toung, so as to hold if trailer comes off ball.
   / BX25 Transporting #8
I have 18' tandem axle 7000 pound trailer for my B3200. I t works well with the tractor as TLB. Haven't tried any other way.
   / BX25 Transporting #9
I'm using a 16' 7000# dual-axle Tuff trailer for my BX24. I wouldn't go any smaller.
Had this one built with surge brakes. Kodiak disks all around. They work very well.
Z.
   / BX25 Transporting #10
I`ve got a dual axle 16ft. trailer...fits perfect...no brakes but i don`t tow it very far , nor very often, and when I do I have a 3500 RAM 4X4 as a tow vehicle.
Cat TH407C Telehandler (A51039)
Cat TH407C...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A51039)
Mitsubishi FG35...
2009 Lee-Boy 8510HD Conveyer Feed paver (A51039)
2009 Lee-Boy...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
