BX25 HST Fan Replacement
   / BX25 HST Fan Replacement #1
dmacneil
Waterloo, Ontario
BX25, BX42 Chipper, 54" Puma; White 20HP
Well now I'm thoroughly in a crap mood. Last weekend I shredded the HST fan on a branch. Figured this wouldn't be too bad to replace. Replacement fan is $11 from the dealer.. sweet. I'll have this done in an hour or two. Crawled under the bota and figured I'd have to disconnect the shaft, two nuts for the fan, bada ding bada boom... Bob's your uncle. Upon closer inspection... wait a sec... um the frame is in the way. Let me refer to the manual..... I have to do WHAT??!! Surely there is a short cut... TractorByNet here I come. No info on the BX25 from what I searched but the BX24: lots of info.. Crap crap and crap upon crap. I now realize this is going to be a long ordeal.
I suppose I'm venting here.. if anyone is interested I'll post on how dismantling the tractor to replace a $10 plastic part goes. Also, if anyone has any tips for this job specifically for the BX25 I'm all ears. (one more "CRAP!!" for the road)
(I don't think I have enough beer on hand for this job... sigh...)
   / BX25 HST Fan Replacement #2
Sad to say this comes up all too often. There are old threads on here about replacement. Some simply split the collar on the fan and glue it back together over the shaft and put a nut on it. Good luck and get a set of Bro Tek or the upgraded HST fan protector.
   / BX25 HST Fan Replacement #3
I can gaurantee you that you will go and get a skid plate or make one for it ASAP after you are done getting it back together.
lol.. already thought about getting one before this even happened.. now I know - NEVER run over ANYTHING
Anybody know how to get the mowing height adjustment and 3PT hitch adjustment knobs off? I tried popping off one of decals, no nut or screw. I tried turning them pretty hard with no results, but don't want to force it too much. Ideas?
(down to 1 beer.. and still haven't got it all apart.. this could turn into a crisis...)
   / BX25 HST Fan Replacement #5
On the BX2200, those two knobs pull straight off.
   / BX25 HST Fan Replacement #6
mine are push ons too. just pull straight out.
gotta love this site.. yep - had to pry them off.. thanks all
just when I think I'm going to get a break.. got the floor pan off, the ROPs, fender and even the old fan (cut it off).. figure I'd be able to disconnect the shaft from the engine and the tranny and be golden.. man.. I bet any who have tried (without reading) have been here before... now I'm debating whether to lift the engine or pull the whole rear end.. for those who don't know, there isn't enough room for the shaft to come off.. argh!!
(and I'm now out of beer... :()
   / BX25 HST Fan Replacement #8
After reading all the things with that fan on this site and finding that KTAC insurance covered it (minus the $250 deductible) I had the dealer do mine, but he stated that all he had to do was move the engine forward and that gave enough clearance for the new fan to go on. Rear end didn't have to come off at all but the front end had to come apart enough to get to the engine mounting bolts.
   / BX25 HST Fan Replacement #9
Good luck with the fan replacement. Definitly not a user friendly replacement process. After reading the different threads on the HST fan weaknesss I waited weeks for my skid plates to come in from bro-tek before venturing out into my wooded back half. It would have been easier to quit drinking :laughing: than not being able to use the tractor back there but in the end I'm glad I waited. If you decide to purchase a skid plate I, like others, highly recomend the Bro-tek plates. Well made, easy to install, and the peace of mind has HUGH value!! The only thing I would have done different was use expedited shipping!!
   / BX25 HST Fan Replacement #10
So you had to pay $250 for the repair with the Kubota insurance?
   / BX25 HST Fan Replacement #11
Yes...overall repair would have cost almost $600 (according to the dealer because of the amount of time it took-as stated, the fan was only $11). And he was on the lower end of the 3 dealers I called.
   / BX25 HST Fan Replacement #12
I thought the upgraded HST fan protector came standard on the BX25..
Well.. job is done. About as much fun as root canal.. actually I've never had a root canal so I'm guessing. :p
I ended up lifting the engine. It really is quite easy. Although on the BX25 the rad shroud is NOT attached to the engine and it needs to be loosened as well (4 bolts). All in all a PITA job for a $10 part, but alls well that ends well.
Enjoy the pics...
BTW, I don't think I'd have had to pull the ROPS, floor pan and rear fenders if I admitted defeat from the get-go and recognized that I'd have to move the engine. :p
   / BX25 HST Fan Replacement #15
Enjoy the pics...
Thanks for the pictures. I have a BX25 so I now have pictures to study if I need to see one stripped. Saved them in my pictures under BX25 stripped.
   / BX25 HST Fan Replacement #16
The upgraded fan protection from Kubota, such as it is, was a mid-course correction and not all current model machines came with it, especially those assembled a year ago, or more.
   / BX25 HST Fan Replacement #17
DMAC,
Dat be dee nakedest BX I eva did see sho nuff . . Ah at least had da cortesy to leave her bucket on . .
Bro Tek front & back plates - order them tomorrow - I did a week after receiving my BX after reading many posts regarding .
Share your pain, though I had to dismantle & reasemble after a hack factory tech replaced my HST input seal and couldn't figure how to put Humty back together again.
Dave
DMAC,
Dave
Wow... deja vu!
   / BX25 HST Fan Replacement #19
Thanks dmacneil
They are the best pictures of the fan removed I have seen.
I would like to ask a question. The bolt that holds the shaft to the splines , how do you get to that bolt? It seems the fan shrouds it and is tight up against the HST cooling fins.
   / BX25 HST Fan Replacement #20
Enjoy the pics...
When you lifted that engine, was the radiator and fan a problem? Or is it all one assembly? How long did it take to get the floor off?
CATERPILLAR SSL PR118M HYD POWER RAKE (A60429)
CATERPILLAR SSL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
S/A Yard Dog Truck (A59230)
S/A Yard Dog Truck...
2017 TERRAMAC RT14 CRAWLER DUMPER (A60429)
2017 TERRAMAC RT14...
FORD 8630 TRACTOR (A60430)
FORD 8630 TRACTOR...
2419 (A60432)
2419 (A60432)
