BX25 FEL Valve Curl Detent
   / BX25 FEL Valve Curl Detent #11
Can you tell me the article# of thr valve ypu want to use?
   / BX25 FEL Valve Curl Detent #12
Artisan, that set up looks good to me, but hopefully someone who has set up a grapple on a Kubota will chime in to confirm from experience.
Thank you Chris and FWIW, I know some guys would be hesitant to "guide" someone, but I know, if I listen, and it is wrong, it is MY fault... :laughing:
Indeed I so appreciate the input from all, not just here but the whole board.
   / BX25 FEL Valve Curl Detent #14
Why don't you use the forward-backward movement of the joystick to operate the grapple, this way you don't have the regen function.
Adryan because I am trying to do this w/ as little hoses and as clean as I possibly can. Your talking about pulling off the fel boom circuit and that would mean a ton of hoses vs maybe 5' total if I use the curl hoses and a valve multiplier. my way keeps all hoses and the valve confined to one small area.
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
Quick Attach 80" Rock Screening Bucket (A50514)
Quick Attach 80"...
2018 Nissan Versa Sedan (A50324)
2018 Nissan Versa...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
2015 MACK CXU613 TANDEM AXLE DAY CAB (A52141)
2015 MACK CXU613...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A52128)
2020 New Holland...
