Backhoe Bx25 BH Install - controls not working
   / Bx25 BH Install - controls not working #1
Megawisdumb
Montevallo, Al
LX2610HSD, Z251, BX25D
Been using my PHD for several weeks and went back to install the BH and after hooking up the 3 lines I can't get the stabliziers or bucket arm to raise. Unplugged the 3 lines 3-4 times to no avail. Any other settings I need to turn off to get the BH controls to work?
   / Bx25 BH Install - controls not working #2
Did you throttle it up .
Yes, went max and oddly the straight through hose jumps a lot when I attempt the stabliziers but no movement on bucket arm or stabliziers only the hose bouncing The BH is sitting flat on barn floor. I gave up and figured I'd try again tomorrow.
   / Bx25 BH Install - controls not working #4
Double check your connections to the manual. Almost sounds like something is in the wrong place or incorrectly connected. I would also check the ball is the connections and make sure they are releasing. Good luck
Hooked it up this morning, turned the wheel L the R and worked like a charm. Not sure what my issue was yesterday but suspect one of the connects was not solid. Life is good.
   / Bx25 BH Install - controls not working #6
Good to hear!!! Glad it is working.
   / Bx25 BH Install - controls not working #7
I had a hose "staying on" one time but a solid pull without releasing the connector pulled the hose off. It was on but not connected. Once on and connected all worked fine.
   / Bx25 BH Install - controls not working #8
check your 3pt lift lever is in the neutral position.
2008 Bobcat T190 Compact Track Loader (A56435)
2008 Bobcat T190...
2017 Ford F-350 Flatbed Service Truck (A56858)
2017 Ford F-350...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
