Backhoe BX25 Backhoe Pin Alignment
   / BX25 Backhoe Pin Alignment #11
Too funny, My bx24 BH (1) side is easy and the other, well, 20lb sludge gets pulled out for the install. Might have to try the sandpaper deal.
   / BX25 Backhoe Pin Alignment #12
I've taken mine off/on a few times just to see how hard it would be. I was surprised how easy it was. No problems, except to remember to turn the tractor off to release the pressure:)
Alignment has not been a problem, but I don't try to lift the rear. I move everything till it lines up and slide the pins in. It does take me a minute or so, but I'm not one to rush something like that and would discourage the use of a BFH to line things up. If it takes that, somethings not right.
   / BX25 Backhoe Pin Alignment #13
My left pin was practically seized when I first removed it, since I dont think it had been removed by the original owner in 3 years but it did come out, I did the grease trick and it is definitely better but always harder than the right pin. I will do what others have tried here and remove a bit of paint. I always have to fool a bit with lifting it for it to come out where the others always just come right out.
   / BX25 Backhoe Pin Alignment #14
I am a newbie also and first time removal was the same problem...left side just would not cooperate (in or out), but in my case, when I dropped the lift on the bucket (weight on the wheels), it comes right out. Nothing like all the videos I have seen.
2018 JOHN DEERE 60G EXCAVATOR (A52709)
2018 JOHN DEERE...
84" HYD CURVED LOG GRAPPLE (A52706)
84" HYD CURVED LOG...
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
SKID STEER ATTACHMENT RAKE (A58214)
SKID STEER...
30KW GENERATOR (A58214)
30KW GENERATOR...
404 (A52706)
404 (A52706)
