BX25 Backhoe hose replacement cunundrum
   / BX25 Backhoe hose replacement cunundrum #1
huntgrouse
US
Kubota BX 25
How the HE double hockey sticks do you get those fittings off of the distro box in the back bottom of my BX25 backhoe? The second fitting in on the right , bottom row, (when facing the box) has a split hose (yellow marker) (4 years old) how do you remove without some weird wrench? or is there no way. I don't see any flare nut socket in 11/16".
and how do I tell what the other end is too. (no smart *** comments here) They are all funneled into the same protector and I don't want to play hide and seek, I would rather know ahead of time what fitting out on the boom I have to loosen.
   / BX25 Backhoe hose replacement cunundrum #2
after removing one end pull on other hoses to find the one you need, sometimes you have to remove other hoses to get the one you want just be sure to mark them first
I gathered that. was trying to find out if there was a correlationbetween where the one end was hooked to the distro box and what the other end was for by location.
still need to know how to get the dman fittin goff. none of my wrenches will fit, very tight.
   / BX25 Backhoe hose replacement cunundrum #4
without thin wrenches may have to work your way in by removing the ones before it, just takes a little time. by the time you find a chart showing what goes where you can have it off.
1991 KALYN SIEBERT 60 TON LOWBOY TRAILER (A51247)
1991 KALYN SIEBERT...
APPROX 500 GALLON FUEL TANK (A51248)
APPROX 500 GALLON...
2015 GMC Acadia SUV (A51694)
2015 GMC Acadia...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A51692)
2013 Ford F-150...
2024 KUHN SL124T LOT IDENTIFIER 60 (A53084)
2024 KUHN SL124T...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
