BX25 - Anything you would do differently?
   / BX25 - Anything you would do differently? #11
get rimguard for the rears. i like tufts but your needs maybe different. ratchet rake is the most fun implement but i think only available at some tsc. i have the worklights,bh dolly-forks from bxpanded...
steve
bx25
   / BX25 - Anything you would do differently? #12
Well I guess it would depend on what you want to use you tractor for.
I have a BX24 with a 12" bucket and R4 tires filled with beat juice as well as
Front blade (Kubota)
Snowblower (Kubota)
Rear blade (Landpride)
Landcsape rake (Landpride)
Box scraper (Landpride)
54' MMM (Kubota)
Bagger (Kubota)
Ripper finger (not sure of the propper term 3pt pice of steel that can penetrate 18") (Off-brand)
Spike airator (Off-brand)
Drum roller (Off-brand)
2" rceiver hitch (ATV type)
   / BX25 - Anything you would do differently? #13
+1 on the Brotek plates. I figured that out the hard way. I have both bucket sizes. Little one for irrigation ditches, big one for most everything else.
QUOTE]
I tried the backhow for irrigation pipe and it was too slow etc. I used a pipe pulled on the BX and pulled all 2000 feet in about 4-hours....
Thanks all for your advice, except that now I'm in for a landscape rake as well.
   / BX25 - Anything you would do differently? #16
I'm about to buy a BX25, and I want to make sure I don't forget anything in the way of options etc. I already have an L3130HST, so the BX25 will be my wife's tractor (she'll let me borrow it to dig holes). My plan is to get a 60" mid mower, canopy, and rear work lights. I also want to be able to use implements besides just the backhoe.
Any advice on what I will wish I had added or not added? Also, any advice on bucket size, 8" vs 12"?
Any knowledge would be appreciated.
I would look into getting wheel spacers for the rear. I have the same setup, BX25 with 60" MMM, and the two inch spacers work perfectly. The added stability is remarkable, and probably better than what would be achieved with filling the rear tires since they are on the small side and not that much weight would be gained.
I like this idea. Where did you get the spacers? Will my dealer have them - I'm headed there Saturday.
   / BX25 - Anything you would do differently? #18
One advantage of a BX is its light weight on turf when mowing lawn. If your sod is soft, that might be something to think about before weighting the tires. If you have no soft spots, it may not matter.
There are so many attachments available, it really would help to know exactly what you are going to do with the BX that you can't already do with the L. It would also help to know a list of all the attachments you already have for the L and what you use them for. Does the L have a FEl and BH? If so, do you really need the BX25, i.e. would a BX2360 meet her needs? For digging these holes, are they post holes or are you excavating for a swimming pool, i.e. would a BX2360 with a PHD meet your needs or do you really need the BH?
   / BX25 - Anything you would do differently? #19
I "believe" the Kubota wheel spacers are designed more for allowing space for chains and are only about 1.5", Bro-Tek offers wider ones for stability. There are some on eBay, but I didn't check to see who makes them.
   / BX25 - Anything you would do differently? #20
Could you explain how you did this? Sounds interesting.
(2) SODA FLO CONTAINERS (A51244)
(2) SODA FLO...
2016 CATERPILLAR 335FL CR EXCAVATOR (A51242)
2016 CATERPILLAR...
2008 HONDA GOLDWING GL1800 TOURING MOTORCYCLE (A50505)
2008 HONDA...
UNUSED FUTURE SKID STEER SIDE SHIFT FORKS (A51244)
UNUSED FUTURE SKID...
2016 Ford Escape SUV (A50324)
2016 Ford Escape...
UNUSED JCT SKID STEER QUICK ATTACH PLATE COMPACTOR (A51244)
UNUSED JCT SKID...
